Need help on this code
Old Jul 9, 2011 | 07:16 PM
Jr.'s Avatar
Jr.
I have a 2001 dodge diesel the sensor comes up with the code mod $15. Does anyone know what this is?
Old Jul 10, 2011 | 02:39 AM
DIESELWRKS's Avatar
What ? is there a code. never heard of what you asked...
Old Jul 10, 2011 | 09:35 AM
Jr.'s Avatar
Jr.
I have never heard of it either. There is another code PO216 along with it.
Old Jul 10, 2011 | 09:46 AM
BigIron70's Avatar
Cummins Guru
My truck had that code but was more like $150. Everytime I take it to dealer it costs me $150.
Old Jul 10, 2011 | 04:37 PM
DIESELWRKS's Avatar
what sensor are you talking about when this came up.
Old Jul 10, 2011 | 05:28 PM
Jr.'s Avatar
Jr.
We are trying to find out what caused the Po216 code. The scan tool said module $15 not responding. We are trying to find out which module is this. We are trying to diagnose a dead pedal.
Old Jul 10, 2011 | 06:12 PM
j-fox's Avatar
0216 is the injection pump timing failure. You need a VP44!
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Old Jul 10, 2011 | 06:34 PM
Jr.'s Avatar
Jr.
Already put a VP44 on it. Still dead pedal. New Position control sensor, new battery, new air cleaner, new fuel supply pump, map sensor, tested ECM checked out okay. intake air temp sensor,checked grounds.checked for air in lines. Wondering if it is possible problems with the transmission can cause this problem. Or could it be I got a bad VP44. The scan tool says Module $15 not responding. No one seems to know what Module $15 is.
Old Jul 15, 2011 | 09:21 PM
Jr.'s Avatar
Jr.
Update- Got it fixed. Got a bad rebuilt VP44. They tested the pump on the bench the brain tested okay. But when it was on the truck with the high temps and the vibration of the engine it would loose contact and mess up. So make sure your rebuilt has a new brain. It would save you lots of headaches.
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
