Need an ECM Expert
Need ECM help.
Can an ECM out of a 2001 DODGE 2500 with a 5.9, 5 speed manual transmission be reflashed (programed) to replace an ECM on a 2001 DODGE 3500, 6 speed manual transmission with an HO Cummins engine? Both ECM's have the same Cummins part number (3947412).
Hmm, I am pretty sure there is a difference between the standard and HO because I had to wait a week in Montana to get an HO ecm overnighted from Michigan to get my truck up and running...but that doesn't mean they couldn't be fooled with by a computer literate guy.....the dealership just couldn't do it or I'm guessing they would have, they had 2 non HO ecm's in stock.
The HO motor uses a different injection pump and the motor runs a higher compression ratio that the SO motors.
I would guess the computers would be different.
It would also guess that it would be able to be re flashed, but that would be a question for the guys who you would ask to re-flash it.
I installed the ECM for 5 speed manual transmission today. It started right up on the first try. All the gauges and cruise control are working. I would like to get the ECM flashed for my HO with 6 speed manual transmission but it is running a lot better than I expected.
Maybe you would not want the re-flash... I remember when the HO came out that folks put on SO VP44s to get a nice boost in performance over the HO.
So if it runs good and does not smoke.. why change it?
Thanks! Randy.
ECM programming info regarding ECM replacements:
TSB 18-019-02A
There seems to be six versions of the firmware in the ECM which depends on two criteria:
1 - Emissions - 49 state (Federal) or California
2 - Transmission - Auto, 5 speed, or 6 speed
TSB 18-019-02A
I am pretty sure I still have a 6 speed '01 ECM in my shop from a truck I drove , before I parted.
