Missing exhaust bolt: broke or backed out?
Old Aug 8, 2005 | 09:07 PM
2500CTD's Avatar
Well I was looking over the engine and noticed that the rearmost top exhaust bolt is missing. I haven't stuck anything in there to cofirm that it backed out completely or just the head broke off. What is more common. I guess with my luck that its broke off. So is this means for a 3 piece manifold, and well since I'm there it would be the best time for a 2nd turbo......................ARGH, er I guess I should figure out what happened first. Only thing I can think of is during that roadtrip to FL the truck overheated on 2 mountains pulls. As soon as I pulled over the "Check guages" light came on Yea so hopefully if its broke there is no tension on the threads since the head is gone. Until I finish typing this, currently there is no exhaust leak, or none that I can hear.
Old Aug 8, 2005 | 09:45 PM
Supermod56's Avatar
Probably fell out, fairly common. Get the ATS 3-piece manifold, you will be glad you did!!!!
Tom
Old Aug 8, 2005 | 10:06 PM
2 busy's Avatar
mine is missing also, doesn't seem to be leaking anywhere.
Old Aug 8, 2005 | 10:08 PM
phox_mulder's Avatar
Sometime in the 2001 model year, Dodge came out with a fix.
Mine has keeper straps to help hold the exhaust manifold bolts in.
phox
Old Aug 8, 2005 | 10:12 PM
torquefan's Avatar
Yep, not a problem. The 24 valves are forever barfing out manifold bolts. There is a bulletin regarding the retaining straps that Phox mentioned.
Old Aug 9, 2005 | 02:41 AM
2500CTD's Avatar
Did a quick scan through Dodgeram.org and didnt see it there. I look more in depth later, unless it is somewhere else? Thanks for the heads up.
Old Aug 9, 2005 | 05:04 AM
Supermod56's Avatar
phox
Thats what I thought also, but my 01.5 did not have the straps. Maybe it was a recall and the previous owner never took it in?? Now I have the ATS Allen screws drilled and safety wired.
Tom
Old Aug 9, 2005 | 05:43 AM
Shovelhead's Avatar
Administrator / Scooter Bum
It's actually a TSB.
Look here:
http://dodgeram.info/tsb/2001/09-002-01.htm
Old Aug 9, 2005 | 06:04 PM
TSB date:
Date: Mar. 02, 2001
Very late in the 2001 model year.
phox
flyingd
Jan 8, 2015 07:50 PM
Brian.B
Jan 7, 2012 01:49 PM
Txwelder
Feb 29, 2008 05:52 AM
rkelley
Jan 2, 2007 08:28 PM
Intercooler
Jun 9, 2005 09:45 AM
