Max Boost
Old Oct 17, 2002 | 07:58 PM
wheels's Avatar
Max Boost
I know I have seen it on this site somewhere but cant seem to find it. [undecided]<br>What is the max boost pressure I should see out of 2002 24 valver that is bone stock?<br>Im seeing around 18-19 WOT, does that sound about right?<br><br>Keith
Old Oct 17, 2002 | 08:00 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Max Boost
I belive that's what the stock, unmodified wastegate is set at.
Old Oct 17, 2002 | 09:18 PM
Snoking's Avatar
Re:Max Boost
That is what I get with my 2001.5 Auto 4:10 rig. SNOKING
RCW's Avatar
RCW
Re:Max Boost
Even if you defeat the wastegate you will never get above the 20 lb range as the manifold pressure sensor will cut off the fuel when the boost goes above the factory settings. You can defeat the manifold pressure sensor with one of the power booster computer kits, and get a bit more pressure.
Old Oct 18, 2002 | 10:21 AM
dodgeman01's Avatar
Re:Max Boost
what will unpluging the map sensor do? On my friends truck with a 70 hp fuel box it made it smoke and run around 32 psi of boost.
Old Oct 19, 2002 | 12:50 PM
BigBlue's Avatar
Re:Max Boost
Dman, your friends fueling box has a boost fooler on it. What that does is trick the MAP sensor into thinking it is only seeing 20 pis when in fact it is really seeing 30 or so.
Old Oct 21, 2002 | 04:29 PM
doug's Avatar
Re:Max Boost
[quote author=dodgeman01 link=board=4;threadid=6016;start=0#54729 date=1034954489]<br>what will unpluging the map sensor do? On my friends truck with a 70 hp fuel box it made it smoke and run around 32 psi of boost. <br>[/quote]<br><br>I wouldn't have the guts to run w/o the MAP sensor, as that will surely set an engine code!
Dually Driver
13
Nov 13, 2007 09:10 PM
GTSDave
Jul 8, 2005 09:06 AM
belfert
Sep 9, 2004 03:23 PM
fishin fever
Feb 22, 2004 08:32 PM
Zino
Aug 15, 2003 10:14 PM
