MAP SENSER ON 24 VALVE
Old Feb 1, 2003 | 12:12 AM
BAD HABIT's Avatar
Is there a MAP senser on 98" 24 valve and if so where is it located!!!. Low MPG. Maybe low power. Nothing else to compare by..... HELP>
Old Feb 1, 2003 | 01:04 AM
BAD HABIT's Avatar
Re:MAP SENSER ON 24 VALVE
Lost 3 hours on phone today about this subject. 2.5 hours here. Whats up with this. Learned that from my kid. Going to bed. No help here today. Somebody's got to know something. Try again tomorrow.
Old Feb 1, 2003 | 10:07 AM
Monty's Avatar
See if this helps.
Be sure to take the IAT sensor out and clean it up with some brake cleaner or carb cleaner. This sensor has been known to cause low mpg and power problems when it becomes dirty.
Old Feb 1, 2003 | 10:30 AM
BAD HABIT's Avatar
Thanks OKIEBRONCRIDER. Going to check MAP senser now. I check IAT bout once a month.
Old Feb 1, 2003 | 03:52 PM
willyslover's Avatar
you didn't say if you found it or not...it's behind the fuel filter about a few inches and a little lower on the 98.5 [towards the driver]
Old Feb 1, 2003 | 05:02 PM
RAM4U2NV's Avatar
I have a 2000 model and my check engine light came on. so I take it to the dealer and they said it was due to the map sensor not getting a reading. My question is my check engine light is now off (not reset by the dealer) and the truck now seems to be running alright. Do I still need to replace the map sensor or not. <br> Thanks Doug
Old Feb 2, 2003 | 11:16 AM
Alan_Reagan's Avatar
[quote author=GOOD_LOOKIN_RAM link=board=4;threadid=10367;start=0#99343 date=1044140532]<br>I have a 2000 model and my check engine light came on. so I take it to the dealer and they said it was due to the map sensor not getting a reading. My question is my check engine light is now off (not reset by the dealer) and the truck now seems to be running alright. Do I still need to replace the map sensor or not. <br> Thanks Doug<br>[/quote]<br><br>Maybe not. A lot of times a fueling box will cause the MAP error. If the dealer reset and all is OK it was probably the box or you could have had a dirty connection at the MAP.
Crazyhorse
Nov 24, 2007 04:07 PM
jd4230
Sep 28, 2006 07:12 PM
muddslinger
Jul 28, 2006 11:44 AM
