LP Dead
Old Jan 7, 2006 | 06:48 PM
Superduty's Avatar
So the impeller came off the shaft ? Was the impeller plastic ?
Could you take some pictures so we see how these things fail ?
Old Jan 7, 2006 | 07:49 PM
iker42's Avatar
Yeah we'll deff. take pics...Tho this didnt die as usuall but could be the cause to the death of them.... The motor still ran, it just had no where to cetch....
UPDATE!!!!THE TRUCK RUNS...IT is out on a test drive now....
Now to get him to buy a Fuel pressure gauge....
Old Jan 7, 2006 | 07:50 PM
Superduty's Avatar
Thanks.
How did the other pumps die ? Electrical ?
Old Jan 7, 2006 | 07:53 PM
iker42's Avatar
The other pumps motor died...
Old Jan 7, 2006 | 08:36 PM
Superduty's Avatar
That is why I guessed electrical. That is usually the problem with these pumps. The motors are too light for the load.
Old Jan 7, 2006 | 08:40 PM
slim51015's Avatar
Originally Posted by iker42
Well the motor on the lift pump was functional, the impeller was spinning freely on the shaft, the shaft is keyed and the impeller is just a round hole, should there be a key or something to secure it to a shaft?...We went and bought a Carter pump at Pepboys for $175 and are gonna put that on tonight...
Mike
Same exact thing happened to my pump about two years ago.Was replaced under warranty.
The impeller rotor is pressed on the motor shaft using a plastic or nylon bushing. The bushing must deteriorate after while.
Old Jan 7, 2006 | 08:43 PM
iker42's Avatar
Ahh that makes sence, my dad couldnt figure out why yhe shaft wasnt connected, he thought that the bushing fell out when he opened it up, but deteriorateing makes sence....i guess it deteriates then spins freely and burns up....more to the mystery of the lift pump...
Mike
Old Jan 7, 2006 | 08:45 PM
iker42's Avatar
Is there a replacement for that bushing, our wekept the pump and the pump runs fine, just w/o that bushing it wont spin, so if we could geta replacement bushing we have a backup bushing
Mike
Old Jan 7, 2006 | 09:00 PM
slim51015's Avatar
If I keep my old pump I would have made a bushing out of brass and press it back on.
Old Jan 7, 2006 | 09:04 PM
iker42's Avatar
Good Idea...Might have to do that, are you good with that kind of work? might send out the LP to you and have you make one up if its wasy enough
Old Jan 8, 2006 | 06:14 PM
iker42's Avatar
Well we got the pics of the Shaft and the Impeller on the Lp...Stay tuned for a thread on it..
Old Jan 8, 2006 | 06:25 PM
piperca's Avatar
I don't mean to highjack the thread, but I like this Walbro pump idea! I'm getting ready to do my VP and was going to do the LP at the same time (even though it's only got 10K on it). Has anyone with 2nd gen done this mod? I'd like some info on how to hook the system up (placement/type of regulator, etc.). I've got the Vulcan relocation kit installed. Would I have to upgrade the hose to the "fuel injection" type, since this pump is capable of hitting higher pressures?
Old Jan 8, 2006 | 07:04 PM
Superduty's Avatar
I'll answer this in the Implementing a Walbro thread to keep it all together.
https://www.dieseltruckresource.com/...434#post861434
Apocalypse
Jul 1, 2008 12:09 PM
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
