LP Dead
LP Dead
Our lift pump died tonight and we were wondering if theres a better replacement then the factory replacement, how to make sure its the lift pump, any way to presever the life of it...
THIS IS THE SECOND TIME IN 2 YEARS that its died...
Mike
Mike
Who carrys the Warlbro pumps?
http://www.autoperformanceengineerin...6000_pump.html
http://www.autoperformanceengineerin.../ext_pump.html
Doesn't look like the PSI or the volume is what we need for our CTD's?
Here is the complete list of threads on this topic.
https://www.dieseltruckresource.com/...ad.php?t=88136
Here is some info on the Walbro fuel injection type pumps:
You can google for other suppliers.
Don't use the carburetor type pumps that Walbro makes.
Implementing a Walbro fuel system:
https://www.dieseltruckresource.com/...040#post860040
Originally Posted by Geico266
I found this on Google. It's spelled Walbro.
The 6000 is a carborator type pump
The Walbro that Superduty likes, along with a pressure regulator, is a good quality, realatively inexpensive, alternative the the stock Carter. The biggest problem with lift pumps isn't necessiarly the brand, or type, but the mounting location. If the stock pump is moved off the engine, to the frame, back by the tank, pump life is lengthened considerably. Its takes a pretty tough pump that will last through the heat, vibration, and VP44 harmonics that are associated with the stock mounting location.
A great place to mount them is on the inside of the frame rail on the drivers side. Just splice into the supply line. The Walbro will easily fit. I'll take a picture of mine mounted on my Ford. The Walbro sites have a mounting kit you can buy.
It is also the heat more than anything, especially with the air cooled pumps.
Well the motor on the lift pump was functional, the impeller was spinning freely on the shaft, the shaft is keyed and the impeller is just a round hole, should there be a key or something to secure it to a shaft?...We went and bought a Carter pump at Pepboys for $175 and are gonna put that on tonight...
Mike
Mike
