Lost power steering / brakes
Old May 31, 2007 | 05:43 PM
happeetxn's Avatar
Howdy All,
My buddy has a 01 Dodge Cummins 4X4 with 169K miles. He stopped today to get fuel and as he was turning into the station he lost power steering and power brakes. His belt is still place and the fluid levels are fine. Is there a vacuum pump that can fail on these trucks?
Thanks,
Craig
Old May 31, 2007 | 06:44 PM
blackdiesel's Avatar
Registered
The power steering pump is behind the vaccum pump. he has hyroboost brakes. If his fluid is fine the pump must have went bad. They usally sound real bad first, but something could have broke in side.
Old May 31, 2007 | 06:45 PM
nickg's Avatar
Fan belt does not drive the Pump, the vacuum pump is only for the cruise and heater controls, kinda sounds like the ears on the pump sheared off/or pump quit, you will have to pull the pump to check it,
the above is just a guess, but I had mine apart not that long ago, and that what I'd say was most likely
Old May 31, 2007 | 08:46 PM
happeetxn's Avatar
Any idea what the pump costs?
Thanks,
Craig
Old May 31, 2007 | 09:02 PM
smokindog's Avatar
Uhh, a vacuum pump for our trucks is in the $2000 range new. It is highly unlikely that he lost the vacuum pump.
Try the power steering pump. They are quite a bit more common.
Old May 31, 2007 | 09:03 PM
Registered
I had to put one on mine and dads with in the las year. I'm think'en they were 80-90 bucks rebiult
Old May 31, 2007 | 09:07 PM
BigBlue's Avatar
Power steering pumps are pretty cheap. I think I paid $160 from o'reilly's for mine. Word of advice though, get the vacuum pump rebuild kit from fixinrams.com and rebuild the vacuum pump while your in there. It's so much easier to pull the vacuum pump and power steering pump out as an assembly and the video that comes with the rebuild kit shows you how to rebuild the vacuum pump. It's very simple to do.
Old May 31, 2007 | 10:10 PM
Registered
BB did you buy a new one? I know that my reman was less than $100
Old May 31, 2007 | 10:12 PM
BigBlue's Avatar
I bought it from o'reilly's so I'd imagine it was a reman. The $160 was including the $45 core charge on it.
Old Jun 1, 2007 | 08:09 AM
happeetxn's Avatar
Howdy All,
Just making sure I am following along here. Is the vacuum pump 160.00 or is that the power steering pump? If the power steering pump went out would that cause him to lose his power brakes as well? I want to make sure I have all my info right so I can help him out.
Thanks,
Craig
Old Jun 1, 2007 | 11:03 AM
Registered
It's a hydro-boost sys. there for your power brakes come from your power steering pump. and yes the P/S pump is what were pricing
Old Jun 1, 2007 | 01:10 PM
happeetxn's Avatar
Thanks Black diesel and everyone for helping me help my buddy.
Craig
MTC
Aug 18, 2014 04:29 PM
Trace
Apr 2, 2009 06:42 PM
FIREBUG13
Nov 20, 2008 08:11 AM
mike7018
Mar 19, 2007 12:47 PM
j
Feb 22, 2004 10:59 PM
