loss or lack of power after long trips
Old Feb 2, 2009 | 06:13 PM
offroad00's Avatar
I have noticed the last couple long trips when I took the truck out on the interstate for 4-5 hrs cruising along at 75-80 mph that once I get back on a road that is 55-60 mph the truck seems to have a loss of power. It takes off fine from the line and gets up to 55 mph, set the cruise and notice on the first slight incline that the truck is slowing down and it takes it forever to shift back down from overdrive to drive on its own. You can push the pedal down more with your foot and get it to shift down and it is fine, but will continue to do this for a while. It has done this to me twice now, both after long trips. If I speed up to 65-70 mph I don't notice it. Any ideas what it would be? Almost like after running that long the computer forgets its settings or something. First time it had me worried when I was up in the mountains and did it. This time was 1300' around my home.
Old Feb 2, 2009 | 11:09 PM
nickg's Avatar
pull the codes! sounds like a "dead peddle" could be an APPS or a VP, but pull the codes to start, with an 02 you can key on key off the ignition 3 times and read the codes in the ODO window
Old Feb 3, 2009 | 05:26 PM
offroad00's Avatar
I did the key trick and only got one code and it is P1693. What does that tell me?
Old Feb 3, 2009 | 08:01 PM
rebal's Avatar
1693 is a companion code it is telling you there is another code try it again. it should flash ecm codes then pcm and p done when finished .also try an APPS reset . but it is sounding like the VP is going
Old Feb 4, 2009 | 09:34 AM
RowJ's Avatar
Problem goes away next day or no?
Only time I noticed anything similar was after 15 non stop drive to Tuscon. Truck Idles rough for a bit. Was fine next day??
Fuel pressure holding good when this happens?
Go to Autozone for free scan with fancier tool. If no serious codes... try complete disconnect of Edge Comp.... as a test. They have acted up before and caused some weird symptoms! Just a guess.
RJ
Old Feb 9, 2009 | 07:04 PM
offroad00's Avatar
I read the codes and have the dreaded P0216. Guess that means my VP44 is on its last leg. Do any of you have recommendations on what to replace it with? I am leaning towards a Blue Chip Special X, but not sure it is worth the extra price. Be nice to get the truck back up into the low 20s again in fuel mileage. Probably will keep driving it for another month or so or until it dies completely.
Old Feb 9, 2009 | 07:57 PM
Captain Coop's Avatar
Just about the same situation happened to me. Dead pedal after long trips along with some other stuff... Im currently saving for a VP, uspecially after discovering i had a bad lift pump.
Old Feb 10, 2009 | 04:05 PM
PaulDaisy's Avatar
I also contemplated a souped up VP when i got 0216. Then I read that all VPs are rebuilt on the same equipment, with the same upgraded electronics unless they are rebuilt by a shady shop. All authorized shops follow the same procedures. So I went with a regular VP and have no regrets.
Old Feb 12, 2009 | 08:32 PM
TRASHMAN's Avatar
have you checked to see if you have a vacum sound when u open the fuel cap after a long trip ? could be CLOGGED tank vent working against the LP Simple leave the cap loose then go for a road trip see if it makes a difference
Old Feb 13, 2009 | 12:56 AM
wow....thats a really good idea. I really hope that will be the problem with mine but i really dout it with my luck.
nvr-enuf
May 8, 2013 11:03 PM
rstl99
39
Nov 13, 2010 08:06 PM
rstl99
Sep 29, 2010 12:13 PM
04ctd
Jan 23, 2007 05:06 PM
TexasBlake
Dec 1, 2004 10:00 AM
