Lift pump replacement instructions?
Old Jul 5, 2008 | 09:03 AM
TXJosh's Avatar
I'm replacing my lift pump today and would like to find some instructions if they are out there. Might save me some time.
Old Jul 5, 2008 | 08:41 PM
Clunk's Avatar
I moved mine to the frame rail just in front of the fuel tank when I replaced the original.
To install at the stock location, I've read it's easier if you loosen the fuel filter housing and set it out of the way for good access to the lift pump. It's pretty straight forward, just remember there's 2 sealing washers for each banjo fitting...1 to each side. I tighten the banjo bolts finger tight then 1/2 turn tighter with a wrench.
Old Jul 5, 2008 | 09:10 PM
TXJosh's Avatar
Yep, I moved the intake manifold and fuel filter to get to it. I would like to move it to the frame but plan to get a FASS later on so will do it then. It was definitely bad so now I'm worrying if my VP44 was damaged and how long it is going to last.
Old Jul 5, 2008 | 09:29 PM
Clunk's Avatar
Been getting the ol' P0216 trouble code?
Old Jul 5, 2008 | 11:28 PM
TXJosh's Avatar
Nope, I've got 460, 463, and 1693. Think my fuel level sensor is going too. I've had a couple times where the fuel guage dropped to empty for a while and then came back up.
JARHEAD
Jun 27, 2010 01:26 AM
PolarisRMK
Jun 6, 2007 08:44 AM
caper
Apr 16, 2006 01:45 PM
jdeereboy
Mar 17, 2004 07:36 AM
