TC Hunting still, Need instructions for Alt. brush replacement.
Old Aug 3, 2006 | 10:50 AM
dctoner's Avatar
Well my tranny is still hunting the lockup, I have done just about everything to fix this issue.
Does anyone have instructions on how to replace/check the brushes in our alternators. Search didn't turn up anything Autozone tested the alternator and it tested fine, but I want to get in there and look for my self. Instructions and pics would help the job go faster.
TIA
Old Aug 3, 2006 | 12:02 PM
Wolfeman's Avatar
What have you done to try to fix it?
Old Aug 3, 2006 | 12:08 PM
dctoner's Avatar
Batteries and Alternator Tested
APPS -- Voltage adjusted .42 volt moved back up to .52
Grounds -- everyone cleaned
ECM -- new ground to battery
ground by alternator -- wrapped and grounded
ECM -- updated with latest flash program
DTT Noise Filter -- going on tonight
Ground from Tranny to Frame
2 RF Chokes, next to P. battery, and alternator.
Old Aug 3, 2006 | 01:34 PM
lumpy_63's Avatar
For me what worked, after trying most of what you tried, was buying an rf choke from radio shack and snapping it around the ground wire that runs over the alternator. I put it near where the wire connects to ground, right after the transmission had acted up (hunting for gears). I intended to move it closer to the APPS later at home, when I could dig the wire out of the wire conduit, but it didn't act up after I put it by the ground connection. It has been over a week now and the trans. has been acting fine. Not sure why since I am not very electrically inclined. Seems like it would need to be between the alternator and the APPS to help but it didnt... Maybe it was just a fluke and the problem will come back later... I got the idea from lwowen's post back in 2004, although he put the rf choke on the wire from the APPS to the PCM.
Old Aug 3, 2006 | 01:39 PM
dctoner's Avatar
Lumpy_63,
for got to list that one, I actually have two of them on by the battery and one by the alternator.
needless to say, this has cured me from ever purchasing an Auto again
Old Aug 3, 2006 | 03:20 PM
Wolfeman's Avatar
One more thing that might help. I got a can of spray contact cleaner and sprayed the ECM plug contacts and the connector plugs under the passenger side batteries.
You said you had the batteries tested but if they are over two years old I would replace them with optima red tops.
Old Aug 3, 2006 | 09:04 PM
mr T's Avatar
TIA
id go back to checking the APPS/TPS...taking the wires out of the loom has worked for many as well if i remember
Old Aug 4, 2006 | 06:19 AM
j-fox's Avatar
I bet the DTT noise filter solves it.
Old Aug 4, 2006 | 09:04 AM
dctoner's Avatar
mr T,
I will look into taking those wires out of that loom.
J-fox,
I do have the DTT noise filter, if anything it made the problem worse. It occurs more often with the DTT noise filter on than off. Which I truly believe that it is not the fault of the noise filter but the circumstances of my problem.
Old Aug 4, 2006 | 01:27 PM
lumpy_63's Avatar
dctoner, sorry to hear that you still have this problem. There is a guy that has a wiring harness advertised on e-bay, I think it reroutes the wires away from the alternator.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Hope you find the solution to your problem soon.
Old Aug 4, 2006 | 03:44 PM
dctoner's Avatar
Looks like Suncoast sells the kit for $48
Old Aug 4, 2006 | 05:32 PM
dctoner's Avatar
Looks like I will be doing this.
https://www.atsdiesel.com/PDF/120505...%2047%20RE.pdf
Old Aug 10, 2006 | 11:32 AM
dctoner's Avatar
Followed the ATS APPS rewire and
DNRCustoms
Feb 21, 2010 12:11 PM
06RAM2500
Feb 12, 2008 08:47 PM
stack_climber
17
Mar 3, 2004 03:00 PM
MoreSmoke
Feb 14, 2004 08:51 PM
