lift pump ???
Old May 31, 2007 | 01:18 AM
dodge_fan's Avatar
lift pump ???
I have a 2001 dodge 24 valve that is having a hard time starting it just started today and has never had this prob. before
When I try to start it it will crank and if I stop the lift pump continues to run for about 1.5 mins then it will start right up.
Does any one have any thoughts on what it could be
I am thinking a weak lift pump as I am loseing preasure
By the way I changed the fuel filter after this started today
Old May 31, 2007 | 02:21 AM
CL2000's Avatar
sounds like the lift pump check the presure b4 driving it.
Old May 31, 2007 | 06:49 AM
blackdiesel's Avatar
Registered
Probley the LP, and could be the ball check valve on the return line on the IP letting it loose prime.
Old May 31, 2007 | 01:41 PM
dodge_fan's Avatar
how would I check that?
Old May 31, 2007 | 02:06 PM
PaulDaisy's Avatar
You should install a fuel pressure gauge in the cabin to see if the LP is working. In the meantime, you can check the fuel pressure using a gauge that attaches to the schrader valve on the injection pump.
-P
Old May 31, 2007 | 06:09 PM
Registered
It's on the return line on the IP, just take it off and see if you can blow though it. It's the banjo bolt on the return.
Old Jun 3, 2007 | 11:22 PM
dodge_fan's Avatar
would the check valve be in the line or in the IP
I changed the LP this weekend but it is still doing the same thing
other than the the truck is idling alot better
Old Jun 3, 2007 | 11:31 PM
dodge_fan's Avatar
also I checked the codes and there are no codes
Old Jun 4, 2007 | 06:57 PM
dodge_fan's Avatar
could it be bad injectors? and where should I get a good quality guage
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
