lift pump??
Old Mar 3, 2007 | 01:45 AM
frenzel's Avatar
lift pump??
I need a quick replacement pump just till I can afford better this summer. Anyways, I can cycle my key jump up front and listen/feel the lift pump and it aint making a noise or vibration. Dead right? So where can I get one fast. Or maybe cheap? Or both.
Old Mar 3, 2007 | 02:02 AM
xms's Avatar
xms
Holley blue with regulator my friend, been running strong for two years.
Old Mar 3, 2007 | 02:26 AM
frenzel's Avatar
how much........Hows the install
Old Mar 3, 2007 | 02:41 AM
frenzel's Avatar
Can anyone tell me a dealer in south Misssouri? Near Springfield Branson area. I havent been able to find a dealer . Will they still sell the 4090046? I must be retarded there has got to be someplace with a pump down here
Old Mar 3, 2007 | 08:24 AM
Hillcountry's Avatar
I can't answer your location question...sorry. But a Holley Blue will run around $100-120, and it will come with a regulator but you probably won't need it because it pushes 15psi anyway. Most mount it to the frame by the tank and re-plumb the fuel system with 3/8 inch ID line. This gives you better flow and allows the pump to push rather than suck. It takes a little work to do the install, but makes it easier in the long run to replace lift pumps.
It does not go into the stock location. A Carter pump will fit in the stock location.
Good Luck
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
