leaking transfer case
Old Jul 14, 2008 | 04:29 PM
tom austin's Avatar
Question leaking transfer case
i have a slow drip between the transmission and the transfer case. it is a 1998 ram 2500 with automatic transmission. it does not smell like transmission fluid. it feels like 10w oil. should i worry about this?
Old Jul 14, 2008 | 10:16 PM
badme's Avatar
if you keep it full, no. if you forget and run it empty, yes.
Old Jul 14, 2008 | 11:09 PM
oldblues's Avatar
hi
the only fluid in the trany and transfur should be atf+4
look at your transfur case fluid for color , mine was blackish .
rebuilt my transfur case with all new seals , but the real culprut was the seal in rear of trans case !
hi and dry now !
Old Jul 15, 2008 | 01:04 PM
Busboy's Avatar
Originally Posted by oldblues
hi
the only fluid in the trany and transfur should be atf+4 l
Also the xfr case quantity is very small and any leak will quickly put it in danger.
Old Jul 15, 2008 | 02:13 PM
PaulDaisy's Avatar
Isn't most of the transfer case lower than the transmission? Seems unlikely that transfer case seal would leak there, more likely the transmission.
low c1500
Jun 28, 2005 02:35 AM
snakefarmer
Mar 2, 2005 09:38 AM
NOTSTK
Oct 29, 2003 08:56 PM
