Leaking injector?
Old Mar 10, 2010 | 02:13 PM
yarddog's Avatar
Leaking injector?
Hello All,
I'm getting white smoke on start up if my fuel pump runs for more than a couple minutes with the engine off. It seems to be fuel related because I can duplicate it. If I start it right after the heater grid turns off, no smoke. If I wait with the fuel pump on I get smoke. More smoke if it's cold, less if it's at opperating temp. Is this a typical symptom of a leaking injector...or something else? Thanks ahead of time for help!
Old Mar 10, 2010 | 09:54 PM
yarddog's Avatar
Anyone have any idea's?
Old Mar 31, 2010 | 12:18 AM
totalloser's Avatar
Sounds normal to me. The fuel lift pump cannot deliver fuel to the engine directly. The injection pump controls that.
What is happening, is that when you start with the grid heaters still warm, the fuel is burning in the engine as it should. When you sit and let the fuel pump run, the grid heater is allowed more time to cool down, and so when you fire it up, the engine is dealing with colder air, so the fuel is not completely burned. The white smoke is unburnt fuel from a cold burn.
Keep in mind, the fuel in the engine is ignited by the heat of compression. If the air coming in is colder, it makes it harder to burn the fuel. If the engine is colder, it cools the air also. Cooler air means less effective burn-unburnt fuel=white smoke.
In short, don't worry about it at all.
Old Mar 31, 2010 | 12:48 AM
johnh's Avatar
sounds right to me!
lilsuzuki4x4
Sep 1, 2011 01:50 AM
Jambbii
Nov 5, 2004 10:59 AM
berner
Mar 7, 2004 09:02 AM
bwat4
Feb 6, 2004 09:32 AM
yomitch
Apr 21, 2003 06:28 PM
