A Few Questions For Anyone With FASS DDRP
Old Mar 19, 2010 | 08:16 PM
lancaster's Avatar
The lift pump on 2002 is stock and still working but I've noticed in the past 6 months that I can get the pressure to drop to 5 psi without too much trouble. I'm still seeing 11 or 12 psi at idle but would like to put a new pump on the truck before heading out on holidays this summer. I've been thinking about the FASS DDRP and then I can keep this one as a spare but I wanted to hear from some DDRP owners first. My questions: What kind of pressures are you seeing at idle and WOT? Did you mount it in the stock location or on the frame? How long have you had it?
All replies are greatly appreciated. Thanks.
Old Mar 19, 2010 | 08:47 PM
estrada5.9's Avatar
I would go to the FASS website and get that info first hand.
You can also look at the installation manuals as well on their site.
Old Mar 19, 2010 | 09:05 PM
birddoctor's Avatar
I've had mine for 2 yrs.Its mounted on the frame beside the tank.I got rid of the stock pump and fuel filter.I have 16 lbs of pressure most all the time.Its very well worth the money!!
Old Mar 19, 2010 | 11:08 PM
hammerdowndodge's Avatar
i love my fass 150-150. i also took the stock pump and filter off the truck. if you get the fass with the filters i would go with the shorter filters if u drive in the snow any. the long filters hang down a little too far for my taste and they seem to catch a little snow. i see 15.5 psi at idle have not seen it down past 10 psi puttin the hammer down. mounted it on drivers side where fass says too, kept as high as i could. have about 80k miles on it. i also found after puttin the fass on i have not jelled up once. i think that the rubber line acts as a insulator. just puttin in my two cents
Old Mar 20, 2010 | 07:41 AM
wurkenman's Avatar
Or instead of buying more electric crap to fail on you, why not try this. I just ordered one and am now waiting for delivery. I kind of like the idea of more engine rpm's, more fuel pressure.
http://www.dodge-diesel.org/9fubomelipus.html
Old Mar 20, 2010 | 09:14 AM
Ruralmedic's Avatar
I've had mine for almost a year, and it's mounted in the stock location. WOT pressure has never dropped below 10psi, idle is around 14psi. I know there is a lot of negative discussion about this pump on the internet, but for stock or mildy modified trucks, I believe this is a premium alternative to the Carter pump for the PRICE. Plus it has a 4 year warranty.
I believe fuel pressure issues are only part of the problem with VP44 failures. 80% of the failures are the fragile electronics. There are two youtube videos that demonstrate removal and installation of Dodge/Cummins VP44s, and both trucks had the expensive, aftermarket frame mounted fuel pumps, and yet both still had VP44 failures!
Old Mar 20, 2010 | 11:34 AM
wurkenman's Avatar
The ecm code P0216 is just that. Injector pump circuit malfunction.
Old Mar 20, 2010 | 06:48 PM
lancaster's Avatar
Thanks for the input guys. My truck is stock and I'm not planning any mods so the DDRP would work for me. I saw some negative info about the pump somewhere and wanted some feedback from guys who have been using it for a while.
Thanks again.
Old Mar 20, 2010 | 08:21 PM
nitrousn's Avatar
Thanks again.
We installed one for a customer and it is working very well. When my pump fails I would buy one.
Old Mar 22, 2010 | 05:41 PM
odbud's Avatar
I installed a DDRP when the VP-44 went south on me. Works great for me, 15-16 psi cruising, 10psi at WOT
Old Mar 22, 2010 | 07:43 PM
diggerfan99's Avatar
Got a Fass 95, running edge j/a, no problems, 16-17psi most of the time, never below 12psi.
Old Mar 22, 2010 | 09:21 PM
rams2500's Avatar
I've had mine for a couple of months now mounted in the factory spot. Easy install and very happy with it. Idles around 20psi. Can pull it down to 10 to 12 under heavy throttle with the edge on 3. My stock trans can't take any more than that anyway. I recommend it.
Old Mar 28, 2010 | 07:43 AM
phal's Avatar
at idle
At idle, 17 psi on a new ddrp. I am waiting on tires so I have not put the truck on the road so no WOT from me....gary
Old Mar 28, 2010 | 01:47 PM
southerman's Avatar
mine ddrp does great , it stays at 19 at idle never below 15 wot mounted on rail just love it. its basically stock .
Old Mar 28, 2010 | 07:00 PM
Gambino-01's Avatar
I mounted my ddrp in the stock location and i'm at 19-20 idle and 13-15 wot with edge juice w/attitude on level 2 and rv275 injectors towing roughly 12k
