Just died
Just died
When the injection pump goes will they die like you turned the key off. Started it up this morning run fine got on hwy and it just shut off fuese are good check engine light on now got fuel pressuer codes don't know I do not have a code reader
If you have lift pump pressure in the bump/run pump mode by loosing the banjo fitting while pump running??? Do not pass go, do not collect 200 dollars, go directlly to your favorite pump supplier and have fun for five hours or so. All will be good afterwards.
Administrator / Scooter Bum
Both of my Injection Pumps died like someone cut the key off, no warning, no stumble, no hiccup,.....just driving down the road, hit the throttle....then silence.
Tommy93w350
20
11-01-2005 11:07 PM
drew03
09-21-2005 09:56 AM
