The truck just died and would not start!
Old Sep 21, 2005 | 09:34 AM
drew03's Avatar
Unhappy The truck just died and would not start!
My girlfriend bought a 01 2500 2wd quadcab, standard output w/ 5 spd last january. She has not had any problems with the truck so far. Last night she called me on her way home and said her truck quit. I changed the fuel filter at the side of the road, that did'nt help. The fuel gauge said 1/4 tank. The truck has 85k on it, I was thinking it might be the injector pump . We hauled it home and called the dealer today, they said 2001 models have trouble with the fuel gauge. It turned out the truck was out of fuel. A lot better then an injector pump. Anybody else had a similar problem????
Old Sep 21, 2005 | 09:46 AM
dodgediesel4x4's Avatar
There are many folks that have had this problem, and it doesn't just happen to the 01's. Make sure that this problem doesn't happen again (i.e. go by milage instead of the fuel gauge). Every time you run outta fuel, you cut off lubrication to the IP and that will seriously reduce its lifespan.
I'd check for codes and hope that didn't set the IP death code (P0216).
Old Sep 21, 2005 | 09:56 AM
drew03's Avatar
when i changed the fuel filter there was still fuel in the filter housing.
mario_lima1
Sep 1, 2014 01:19 PM
JSPulliam21
Jan 14, 2008 07:52 PM
Steve10
May 4, 2007 11:31 PM
evan3000
Feb 14, 2007 10:56 PM
tthomass
20
Aug 19, 2005 09:35 PM
