Truck died and will not start, help!!
Old Aug 24, 2014 | 09:27 PM
mario_lima1's Avatar
Hello everyone, new to the forums here! Well, a week ago I started my truck to go to work and six blocks away from the house it just died. I parked it gave it a couple of cranks but it did not start. I had it towed back home, did a fuel pressure test and the pressure from the pump was below 14 psi, so I changed the pump (inside the tank pump), I replaced the filter and also replaced the FCA. The truck is not throwing any codes! The truck has 175500+/-, It has a Edge Attitude, cai and exhaust done. What else can I test or replace without doing the injection pump or injectors yet?
I also checked all of the fuses.
2004 Dodge Ram 3500 5.9 Cummins, stick shift, quad cab, not 4X4.
Old Aug 24, 2014 | 09:53 PM
6.7L MegaCab's Avatar
Welcome to DTR! One of the first things I would do is isolate the Edge to make sure that isn't the culprit. If that doesn't get the truck started, the next thing i would look into doing is a compression check on the cylinders, although it sounds more of a fuel issue. These are just my thoughts. Some of the more experienced folks will hopefully follow up very soon.
Old Aug 25, 2014 | 12:35 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I agree with ^ remove the Edge before you do anything else
Old Aug 26, 2014 | 11:15 AM
Thanks for the replies! I disconnected the Edge completely and nothing! I am at a loss here... I was expecting more people to chime in but I guess I am in the wrong place.
Thanks 6.7L MegaCab and Lary Ellis!
Old Aug 26, 2014 | 11:30 AM
Try posting in the 3rd Gen section. Sometimes folks overlook this section.
Old Aug 26, 2014 | 07:06 PM
Hesperus Gus's Avatar
Not sure if it's the same but, the fuel shutoff solenoid on my 12V will not open sometimes. I turn the ignition on and manually click solenoid and it fires right up.
Old Sep 1, 2014 | 01:00 PM
UPDATE!! It has been a few days, I did a lot of reading and it paid off. This morning I went and disconnected the FCA and what do you know, the truck started right away! I was a little shaky and it puffed some black smoke but I turned it off connected the Edge and FCA and truck is like new. Thank you to the guys that responded to my initial post.
Old Sep 1, 2014 | 01:19 PM
Glad to hear you got it running!
Mark Hodowanec
Dec 1, 2012 06:42 PM
ado2b1
Jan 8, 2010 04:27 PM
evan3000
Feb 14, 2007 10:56 PM
drew03
Sep 21, 2005 09:56 AM
GlennRMK
17
Jul 22, 2005 09:11 AM
