jumping rpms
Old Sep 24, 2011 | 03:23 PM
dg164's Avatar
jumping rpms
hey i got a 2002 dodge ram 24 valve and when im cruising down the road dong about 80km/hr if i lightly accelerate my rpms will start jumping from about 1000 rpms to 1300-1400 rpms but the truck wont go faster unless i step on the gas heavily any idea what this could be?
Old Sep 24, 2011 | 07:23 PM
whiskers's Avatar
Sounds like Torque converter unlocking. Pressure might need adjusting. You can do a TC lock up switch to verify the problem. Lock it up with the switch and then see what happens when you accelerate. If rpms don't jump and truck slowly accelerates it is the lock up.
Old Sep 24, 2011 | 10:43 PM
Mike Perez's Avatar
Clean all your grounds first, including engine block and alternator.
Old Sep 25, 2011 | 12:07 AM
dg164's Avatar
alright thanks guys! i did the water pump today and replaced the belt and so far the issue has dissapeared i dont know why but i will definately take your advice into consideration
COLEMAN1001
14
Oct 19, 2007 11:38 AM
joking
15
Sep 19, 2003 06:02 AM
DODGEBRIAN
Apr 5, 2003 12:34 AM
pull superbee
Jan 30, 2003 09:26 PM
