Injector Pump
Old Oct 3, 2004 | 10:48 AM
twhite's Avatar
Injector Pump
I have had to replace two injector pumps. The first one was at 97,000 and second one at 210,000 miles.
Is this about normal or do I possibly have a problem causing these failures?
What can I do to minimize these failure rates?
Is there a source of supply for injector pumps? The last one cost me about $1500 including labor. There must be someplace that have rebuilds that sell for less.
Thanks.
Tim
Old Oct 3, 2004 | 06:55 PM
zulusafari's Avatar
Do you have any gauges installed? Get a Fuel Pressure gauge to monitor your lift pump condition. If it is weak, it will toast the Injection Pump eventually.
Old Oct 3, 2004 | 07:58 PM
graphitecumnz's Avatar
fuel pressure gauge to monitor the lift pump pressures and/or fuel delivery modifications...
Old Oct 3, 2004 | 08:09 PM
phox_mulder's Avatar
Re: Injector Pump
That's not bad mileage out of them.
Almost 100,000 per.
Really the only thing you can do is monitor the lift pump pressure.
24 valve injection pumps are cooled and lubricated by the fuel they are pumping,
keeping a steady flow to them prolongs their life.
Another preventative measure is use a fuel additive.
It will add a measure of lubricity to the fuel, and help keep your injectors clean.
Just don't use and additive made for gasoline engines, as most of them contain alchohol which is a lubricity destroyer.
Powerservice, Stanadyne, Lucas are a few of the big ones.
I'm sure I've forgotten someones favorite additive,
if you do a search here for "additive" you'll find the ones I missed.
phox
Old Oct 5, 2004 | 05:35 PM
MCummings's Avatar
That's great mileage out of a VP44 injection pump, and $1,500 including labour ain't bad at all.
I change out VP44's from $1,350 to $1,450, including the pump, but I need your old pump back.
My first VP44 went out at 75K without any mods, since 75,000 miles, I've replaced 4, and now, VP44 #5 is almost dead.
Run some lubricant through them (NOT Tranny fluid), I would do as Phox recomended, and that can extend their life. (Maybe I should listen to myself, LOL)
Merrick
Old Oct 8, 2004 | 12:10 AM
Pa outlaw's Avatar
i ussually do an injection pump for 1300 and thats includding the labor also,keep the fuel preasure high and stay away from stations that re known to have water in the fuel, this will take a pump out quick
gablekevin
Sep 19, 2006 12:12 AM
jbevly
Sep 5, 2006 03:59 PM
loveturbowine
Jul 26, 2005 05:50 PM
Puke
May 22, 2003 12:18 AM
