Injection Pump Question
Old Mar 16, 2010 | 12:20 PM
maroonbeast06's Avatar
i was wondering about doing a banjo bolt upgrade to get the fuel pressure up in the injection pump. my buddy did a homemade fix and said that it floods the engine for a little bit but overtime it got use to the extra fuel. what would be the gain in doing this. i have a fuel pressure gauge on the injection pump already.
2001 ext cab short bed cummins 47re, vp44 hotrod,fass150,75hp sticks, draw straw,homemade intake, diablo power puck, silencer ring has a new job as a wind chime,......... in the mail is a quadzilla
Old Mar 16, 2010 | 01:50 PM
nkennedy's Avatar
Get rid of the banjo bolts, and put in regular JIC to hose barb fittings. Much more stable pressure thru out the primary fuel system.
Old Mar 16, 2010 | 02:08 PM
tanderson2002us's Avatar
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
A big Line kit from Vulcan has all the stuff you need.....did mine and have no regrets. You do need to drop the tank to install the pick-up fitting but not a big deal. I run 1/2" from the pick-up tube to the VP, with the Holley it holds 20psi at Idle and 16psi wide open.
BTW....good to see some Texan's on here! I am from Fort Worth but live in Newman Lake WA, these days.
Tom
Old Mar 16, 2010 | 02:38 PM
AggieJustin's Avatar
As the other guys said, skip the banjo bolt upgrade and go to a Big Line kit.
I originally did the banjo bolt upgrade years ago, but then upgraded to something similar to what is now in the Vulcan kit. I didn't replace the fitting at the tank, but all banjo on the supply side of the system have been replaced with AN fittings and my fuel pressure from the stock lift pump never drops below 10psi.
You don't have to worry about "flooding" the engine. This upgrade only supplies more fuel to the VP44 which is beneficial since it provides added flow for cooling.
Old Mar 16, 2010 | 03:28 PM
ok then thanks for the help guys and yes i never see below 15psi on my pump gauge i guess i am just worried about my baby
a man and his dog a bond that can never be broken
Old Mar 16, 2010 | 08:38 PM
DodgeRamdiese01's Avatar
hey just curious how much does this vulcan line kit cost? I think it is something i wanna do
Old Mar 17, 2010 | 09:35 AM
I went with the Draw Straw V for $49.99
http://www.vulcanperformance.com/Dra...Flow-p/dsv.htm
And the big line kit for $116.00
http://www.vulcanperformance.com/Dra...p/vpps9804.htm
My Holley pump was about $130.00 at Autozone. I also got a Moroso spring for the pump to get the 19-20 out of it, don't stretch the spring too much or you will get 30-35 psi!
I put this stuff in last summer and no issues yet.
Tom
Old Mar 17, 2010 | 11:58 AM
Yeah I just bought and returned a holley last week. because I thought my lp was taking a dump after a year, money is tight so I returned it, I will have pick one up i guess , where did you get the moroso spring? also did you use the regulator?
Old Mar 17, 2010 | 04:52 PM
I got the spring at a place in Spokane, WA called General Store....anything from hunting gear to car parts. I did not use the regulator and removed the screen.
Old Mar 18, 2010 | 12:48 PM
yea i have the drawstraw from fass and the 1/2" hose from the tank to fass then fass to ip
i shall now call my home state the republic of texas cant wait till we pull away from all these other yaaaaahoos
tommurray
Feb 23, 2014 10:38 AM
billygoat02
Dec 29, 2005 11:03 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
cheng
Jun 22, 2004 12:01 PM
