info for replacing VP44
Old Sep 10, 2005 | 07:17 PM
rigby38's Avatar
Need info for replacing VP44
I have a 99 with 58000 miles on it lp went & took VP out Iam taking it apart now I have all the tools included the one to turn the engine over to TDC my ? is do have totaly all the fuel lines or just loosen them the last one is a bear for this old fat man
Old Sep 10, 2005 | 08:02 PM
smokindog's Avatar
You can do it and leave the HP lines in place, but it is tough. Best to have a helper.
Also here is a great link describing the procedure in detail;
VP 44 Replacement
Old Sep 10, 2005 | 08:21 PM
rigby38's Avatar
Thumbs up
Thanks that helps a lot & the pictures are great too
Old Sep 10, 2005 | 08:28 PM
smokindog's Avatar
Also, may want to order yourself one of those gear pullers from Blue Chip. It is fo' shizzle!
Old Sep 10, 2005 | 09:17 PM
rigby38's Avatar
I was gonna use my snap on puller set
Old Sep 10, 2005 | 09:28 PM
smokindog's Avatar
As long as you have one that is small enough and has a blunt head on it. If I recall correctly the pump shaft does not have an indent in it. Also, be very careful not to continue cranking once the shaft seperates from the gear as it is possible to crack the timing cover when using a t-bar puller as the factory service manual recommends. If you do that you'll be in a world of..... Oh, also place a pencil magnet on the center of the shaft when you start to remove the nut and lock washer by hand. This will ensure that that neither of them fall into the timing cover.
Old Sep 11, 2005 | 01:59 AM
Haulin_in_Dixie's Avatar
I'll give you a little tip that I have found to work well. If you have a leak at the injector lines in the back of the vp, it is like impossible to fix it. I have gone to installing the lines and tightening the pump side first then the injector side. Tightening the pump side first seems to stop leak possibilities.
Old Sep 12, 2005 | 07:57 AM
rigby38's Avatar
got it out yesterda no problems thanks to the help I reciecved here Thanks all I did use my snap on puller but just tighting the bolts in the gear popped right off no problems I did go ahead & remove the fuel lines in 2 sections perfect not as bad as a job as iI thought Now I have to find a replacement VP44 not gonna be pretty
wbuck1963
Apr 27, 2007 05:01 PM
chiefallred
Jan 24, 2007 07:11 PM
Flatty
Nov 21, 2005 10:38 PM
Zeddy
Sep 4, 2004 10:04 AM
Yukon Dodge
Jun 22, 2004 06:32 PM
