Replacing The Vp44
Old Jan 20, 2007 | 03:23 PM
chiefallred's Avatar
Unhappy Replacing The Vp44
Ok bitin the bullet and replacing the vp44 (99 will not start)
got the lines off and everything else i understand needing off except the nut on the vppump holding the gear on. when i try to loos'n nut the whole engine turns, aaaaaaaahhhhhhhh. if it wern't for bad luck i'd have no luck at all.
The wife's chev. venture died with a blown head gasket @ 170,000 miles, no mechanic wants to touch it and chev wants $1000 just in labor. put the van to rest and bought a new car for her
well thanks for allowing me to vent any helpfull info on this vp44 task would be very gratefull. cheapest pump replacement i could find is $1150, has anyone rebuilt theirs with any luck.
Old Jan 20, 2007 | 03:31 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Poor man's Impact Wrench:
Put a wrench on the nut.
Hold the wrench with one hand.
Hit the wrench to the left with a hammer. (Don't hit hand holding wrench with hammer)
Might take a coupla whacks.
Should break the nut loose.
Old Jan 20, 2007 | 07:28 PM
REF>Lancer's Avatar
I used a pipewrench on the balancer,kinda open it up and put in on sideways,the engine can only turn till the wrench hits something,make sure that it don't hit anything delicate!
Shovelheads idea works good too...my hands allways end up sore that way.
Old Jan 20, 2007 | 10:36 PM
high country's Avatar
if it is a manual put it in gear and set the brake.
Old Jan 20, 2007 | 11:04 PM
REF>Lancer's Avatar
Nice,I used that one on mom's honda,dunno why i did not think of it on my truck,freaked out I guess!
Old Jan 20, 2007 | 11:12 PM
no auto, did that trick on the ol '46 ******, works good with manual
Old Jan 24, 2007 | 08:58 AM
Ok, got the nut off now along with 3 bolts for pump plus 2 bolts on support bracket on block. used a homemade gear puller for the gear and popped it loose ( assume the gear stays in the housing being it is larger than the vent hole access) and is now sliding freely on pump shaft. cannot get pump off block. afraid of messing ol pump up, sure don't wanna loose the core credit on the new one. no feedback on rebuilding yourself so i guess it's best to buy.
thanks in advance
Old Jan 24, 2007 | 02:31 PM
cditrani's Avatar
The following was in another thread which I can't find at the moment. I did not write it and I'm sorry I can't credit the author as I don't remember who it was:
VP44 replacement
Read these directions completely before you start. Look at your engine
and read it again. Step 11 under installation requires some advance
planning.
Tool list
3/8 ratchet
1/2 ratchet
8" 3/8 extension (wobble is best)
3/8" drive 10mm socket
11mm deep socket
15mm socket
13mm socket
19mm (or 3/4) wrench (angle is best)
17mm wrench
8mm wrench or 1/4" drive socket)
T-50 torx
Small "T" puller or gear puller
Pliers
Oil filter wrench (looks like a pair of pliers) or strap wrench
1/2" drive 24mm socket (alternator nut)
1/2" drive 27mm socket (vp44 axle nut)
3# retrieval magnet
Inspection mirror
Flashlight
Catch pan
1. Either disconnect the batteries, or cover the drivers side battery
with a fender cover
2. Loosen the top intercooler boot clamp on the intake hat.
3. Remove the 5 10mm bolts on the intake hat (4 hold down and one for
the oil dipstick). Remove the intake hat and place on the work bench.
Lift the grid heater and lay it over on the PDC (next to the battery)
4. Using a piece of bailing wire or the like, pull the intercooler tube
over to the drivers battery and secure it out of your way (wire to the
battery hold down clamp).
5. Remove the 3 13mm bolts on the TPS housing. Lift up and disconnect
the wire harness. If your unit has the harness holder on it, use a flat
blade screwdriver to open it and lay the TPS housing by the gird heater.
6. Remove the first three 10mm bolts that hold the injector lines down
to the engine, starting from the front of the engine.
7. Disconnect the two wire harness connectors on the fire wall to give
you more work room to cyl. 5 and 6.
8. Disconnect the VP44 wire harness
9. Now I like to get the fuel filter out of the way for more room, so I
remove the rear 17mm banjo from the fuel filter (line from the LP). You
can skip these (***) fuel filter steps if you wish) You are going to
want to place a catch pan ender the engine.
10. Drain the fuel filter into a catch pan – water drain, make sure you
close it when it is drained (***)
11. Remove the two 10mm mounting bolts holding the fuel filter. (***)
12. Remove the 8mm bolt, cap, and blue bushings on the injector line
clamp just in front of the lifting eye by cylinder #5.
13. Release the clamp on the crank case breather hose and remove the hose.
14. Using the oil filter pliers, unscrew the crank case breather on the
timing cover and remove.
15. Remove the 27mm nut on the VP44 axle. Using a 3# magnet or better,
grab the lock washer on the axle and remove ***DO NOT DROP IT DOWN THE
TIMING COVER***
16. Emergency brake on, vehicle in neutral or park, use the 24mm socket
on the alternator pulley and rotate the engine CCW until the notch on
the VP44 timing gear is at 12 o’clock. Inspection mirror and a
flashlight is handy.
17. Use the T-puller to separate the timing gear from the VP44 axle. Two
threaded holes in the gear. It will “pop” and move back and forth when
free. Remove the puller. More detailed info as posted by MACHINEST - The
gear stays in the housing, make sure the key is at 12:00, there is 2 ea
drilled and taped holes in the gear, back the nut off about 3/16 of an
inch,put a puller on the gear and pop it losse,then take the nut and
washer off,have a screw driver at the end of the pump shaft when doing
this,because you don't want to drop the nut and washer in the gear
set...be very carefull when putting the pump back into the gear,woodriff
key,and if not lined up perfict you will roll the key out of the pump
and if will fall you know where...A good lite and a small mirrow should
help.....
18. Remove the 17mm banjo from the VP44 fuel supply from the filter.
Catch the washer on the inside.
19. Lay the fuel filter down in the bottom of the engine compartment out
of the way. (***)
20. Remove the 19mm banjo return valve from the VP44. Catch the washer
on the inside.
21. Use the 19mm wrench to unscrew the injector lines at the valve cover.
22. Looking at the back of the injection pump, top is 12 o’clock,
battery is 9, unscrew the 6, 7:30, and 9:45 injector lines and remove
(should be cylinders 1,2, and 4).
23. Unscrew the 12, 4:30 and 2:15 (in this order is easiest) and remove.
24. Using the 15mm socket and extension, remove the four nuts on the
VP44. Two outside (battery side) and two inside (block side).
25. Using the 13mm socket remove the two lower bolts on the rear support
bracket (block side next two the PS pump). Now I have seen 10mm, and
15mm bolts down there, depending on year. Sometimes only one.
26. Remove the VP44.
27. Now on the 98.5 – 2000, there was a rear support bracket that was a
real poor design and broke. If you encounter this (yours is broke), you
will need to replace it and there is some work involved. YOU MUST HAVE
THE REAR SUPPORT!!! If yours is broken, and you do not replace it, you
will trash your pump.
28. Set the old pump upside down on your bench next to the new one. Make
sure they are oriented the same. Transfer the support plate from the old
pump to the new.
29. Stand both injection pumps on end and clock the two axles the same.
The top of the injection pump (circuit board) being 12 o’clock, and if
you rotated the engine, your old pump key way should be at about 10:45.
DO NOT TURN THE OLD PUMP SHAFT!!!
30. Using a paint marker, or some sort of bright color paint, color the
front edge of the key, and a straight line down the shaft threads to the
tip of the axle on the new pump. This will help you make sure it is
aligned correctly when you install.
31. Make sure the new pump has the o-ring installed on the mounting flange.
INSTALLATION
1. Set the new pump into position and insert into timing gear. Start 1
or 2 of the 15mm nuts on the studs to hold the pump in position.
2. Using the inspection mirror and light, look at the gear from the
front of the engine and see if the line you painted is lined up with the
notch in the gear. You should be able to see the front edge of the key
through the notch. If not, remove the pump and adjust. DO NOT CONTINUE
UNTIL YOU GET IT LINED UP. If the key is “almost there, only a 64th of
an inch off” it is not there. It is possible to press the gear onto the
pump with the key not aligned and really screw things up.
3. Snug up all 4 15mm nuts on the mounting studs.
4. Set the new lock washer and nut on the VP44 axle, and snug (35 ft #)
5. Remove the nut and washer (DO NOT DROP WASHER INTO TIMING COVER) and
verify that the key is in the notch 100% lined up. If not, remove pump
and inspect key for damage and adjust clocking, return to step 1.
6. Once the key is verified, install the two rear support bolts and
tighten, torque the injection pump axle nut to 125# and tighten the 4
15mm mounting nuts.
7. Install the injector lines in reverse of removal (block side first)
Tighten the valve cover ends finger tight, then back off ½ turn.
8. Mount the fuel filter back into position and install the banjos
(filter and VP44).
9. Install the fuel return valve and line to the VP44.
10. Connect the VP44 wire harness
11. Now, I have a tool at work that hook up to the LP to run it
constantly. After I have the feed lines connected to the VP (filter
installed and return line) I connect the pump to the battery and start
priming the system. You can use a “T” pin to back probe the POSITIVE
side of the LP wire harness and a jumper wire to the battery positive,
and the NEGATIVE side to ground (red wire + black wire - if you have a
new extension). VERIFY WHICH IS POSITIVE IF YOU DO THIS BEFORE YOU
START!!! You can cook your pcm if you do the wrong wires. You can prime
by “bumping” the starter for the 30 second LP run time. I decided this
was a PITA going back and forth from the engine to the ignition 15 or 20
times.
12. With the pump running, watch all the valve cover end injection lines
for fuel. It will typically do 2 at a time, starting at #3. Wiggle the
lines in and out to let the fuel/air out. Once you get good fuel flow,
no bubbles, tighten the lines up and rotate the engine via alternator
CCW (about ½ to ¾ turn on the alt) continue this until all 6 lines are
bled. I will start assembling the other removed parts in reverse of
removal as I do this (waiting for the air to bleed out) Skip the
rotating the engine via the alternator if your are doing the bump the
starter method
a. Crank breather valve, and hose
b. Hand thread the injector line mounting bolts
c. Grid heater and intake hat (only after #2 is bled and tightened)
d. Connect the wire harness’ at the fire wall (only after 5 and 6 are done)
e. TPS housing (only after #1 is bled and injector line mount is tightened)
13. Once all the lines are bled, tighten the injector mounting bolts,
and the 8mm bolt, and blue bushings. Remove the pump power bypass if you
used this method.
14. Verify that everything is installed and tightened up. Start the engine.
15. If you are having difficulty starting, you may have to crack open
the injector lines on 1, 3, 4, and maybe 5. and crank the engine until
you have good fuel flowing at the injector lines. Tighten them back up
and try to start again.
16. Once the engine is running, visually verify that there are no fuel
leaks. DO NOT CHECK FOR LEAKS BY HAD WITH THE ENGINE RUNNING!!!
17. Go to the car wash to wash off the fuel drippins from the engine and
go for a 5 minute drive. Verify that there are no fuel leaks. # 6 is
notorious for leaks (because you can’t get it tight enough due to lack
of room to work).
This is a “Do it at your own risk” list of suggested procedures. The
author accepts no responsibility for any individual attempting to
perform repairs on their own vehicle if injuries or damages occur.
If I missed anything, please let me know.
Old Jan 24, 2007 | 03:06 PM
blackdiesel's Avatar
Registered
I've heard of one guy on here that took his apart and put it back, and it ran. It's most times it's an electronic falure. Yes it can be a little hard to break the seal from the block, be easy but firm, and work it back and forth it will come loose
Old Jan 24, 2007 | 05:22 PM
bentwings's Avatar
You say you took the 3 bolts (nuts) off the pump and 2 bolts off the block. There actually are 4 nuts on the injector pump holding it to the front cover. Did you get them all off??? See item 24 on the list above.
Also the o-ring can be a bit stubborn and there is a short dowel pin that makes it dificult to rock the pump. Don't be rocking and yanking too much or the key will drop down in the front cover. DON'T DO THAT.
It's possible you are hung up on the bracket so you can take the 2 additional bolts off that too.
Mine had some funky insulation stuck on the block that had come loose and tangled itself up with the pump. This stuff was very brittle so I just busted it loose and tosed it. Sure didn't look like very good insulation
Old Jan 24, 2007 | 07:11 PM
thanks for all the info, it was a 4th bolt on the back side.
gonna pick up the rebuilt and install this weekend.
was informed it's best to go ahead a replace the cmp sensor since it is located behind the pump. found best to use cummins part #4921597 if purchasing through cummins. they had trouble locating the part.
gonna hit it again friday and try installing this pump
wbuck1963
Apr 27, 2007 05:01 PM
Flatty
Nov 21, 2005 10:38 PM
rigby38
Sep 12, 2005 07:57 AM
Zeddy
Sep 4, 2004 10:04 AM
Yukon Dodge
Jun 22, 2004 06:32 PM
