I'm stumped, need input!
Old May 12, 2006 | 06:47 PM
piperca's Avatar
I posted a couple of weeks back regarding my campaign pump taking a dive after 1K. I replaced it with another pump I knew was good. Well, this afternoon I took a run to the hardware store and noticed my fuel pressure, that was 13psi when I left, was now 8psi. This is the same symptom I saw with the other pump. I'm now convinced it's something other than the pump ... any ideas?
Something else that's odd is the fuel pressure increases when I brake.
I'm leaning towards the fuel pickup. Bummer is I just filled up!
Old May 12, 2006 | 10:42 PM
davemac's Avatar
Mine does the same thing, I think it`s something electrical. Sitting in the carport I can raise the fuel pressure from 13# to 15# by turning on the headlights, applying the brake (brake lights) & turning on the O/R lights. I`d be interested to know if yours does the same thing.
Old May 13, 2006 | 12:04 PM
hotdram's Avatar
Stupid question for the both of ya'll, but are your FP gauges mechanical or electrical?
~Rob
Old May 13, 2006 | 12:49 PM
davemac's Avatar
Mine`s electric, Westach.
Judging by piperca`s signature, his is too.
Old May 13, 2006 | 04:13 PM
piperca's Avatar
That is correct. I was suspecting the gauge, but this morning the pressure droped to 0psi and jumped up again. I let the truck idle and watched the pressure gauge. Each time the pressure dropped I could hear the pump change tone, it sounded like it was cavitating. I'm going to need to pull the tank module and check it.
Old May 13, 2006 | 04:42 PM
Silverjay's Avatar
I have a Westach and mine does the same thing. 13 with lights off and 15 with lights on.
Old May 13, 2006 | 05:14 PM
duner's Avatar
seems to me if you load the electrical system the regulator should increase the voltage thereby increasing the potential to the pump. just a thought
Old May 13, 2006 | 06:52 PM
ratsun's Avatar
Could it have something to do with the voltage the PCM is sending to the LP?
Perhaps try sending the LP 12v and see if it changes while driving and braking?
Old May 13, 2006 | 07:43 PM
piperca's Avatar
Mine doesn't do that. I suspect you may have tapped into the light fuse?
Old May 15, 2006 | 10:23 PM
davemac's Avatar
Nope, direct to the battery, fused o`course. I tend to go with duner on this one. Not gonna worry about it, as long as I got the fuel pressure...
Old May 15, 2006 | 10:26 PM
piperca's Avatar
The increase I see is when I am braking, the needle climbs 1-2lbs, but when I come to a stop the needle returns to normal, even with my foot on the brake ... strange!
Old May 15, 2006 | 10:40 PM
davemac's Avatar
Could the negative G forces caused by braking react on the fuel in the lines and cause an increase in pressure at the sonsor?
Old May 15, 2006 | 11:14 PM
piperca's Avatar
You may have something there, but I still think it's odd.
This weekend I'm going to R&R the fuel tank module with a new, larger, pick-up ... I really hope it works. I'm finally going to break down and buy a Walbro and regulator. I think some TLC on the fuel system and I'll be back in business.
I've got a job interview tomorrow. I hope she doesn't leave me stranded on the way!
Old May 15, 2006 | 11:18 PM
davemac's Avatar
Good luck with it. Let us know if it works.
Old May 16, 2006 | 04:33 PM
Cmonroe's Avatar
It is normal for fuel pressure to go up as you let off of the throttle and apply the brake. When then engine is under load the pressure will drop and then return as the load drops off. A 24v stock lift pump gives 14 to 15 psi without a load, under normal load mine drops to 8 to 9 with the box off, under fuel throttle and the box on the new Edge will drop your stock pusher pump to 3psi.
csramsey640
Nov 3, 2019 06:01 PM
1985cucv
Oct 17, 2008 06:41 PM
Joe Diesel
Nov 12, 2007 08:59 AM
greasy
Sep 13, 2007 03:36 PM
doug60
Jan 30, 2005 07:42 PM
