Hows everyones 6speed
Old 04-15-2003, 12:29 AM
Haulin_in_Dixie's Avatar
Re:Hows everyones 6speed
[quote author=dodgeman01 link=board=4;threadid=13560;start=0#127849 date=1050329233]<br>I have a friend that runs a hot-shot business and he has 4 trucks with the 6spd tranny over 130k. Pulls a dual tandem 30ft G/N trailer with them. He said he loved the 6spd and would never go back to a 5spd.<br>DM01<br>[/quote]<br><br>I agree with the not going back but I do have the NV5600SS model ;D
Old 04-15-2003, 01:22 AM
AKDSLDOG's Avatar
A tad notchy going into third, but if the rpms are right it is smooth. Other than that 23,000 miles and no worries. 8)
Old 04-15-2003, 11:04 AM
perk's Avatar
Ours is smooth shifting, with 120k.
Old 04-15-2003, 05:35 PM
patriot pearl blue's Avatar
mine with 12k is a little tough to get into first once i start it up and idle it down the hill in neutral-<br><br> i really have to shove it into first, so i usually just start off in second gear &gt; i'll take it to the dealership once it ticks me off enough-<br><br>oh, and reverse is a tad tough to get into also-
Old 04-15-2003, 06:46 PM
Cold Diesel's Avatar
30K miles. Grinds into 3rd when cold. Grinds a little when hot into 3 &amp; 5. Will not go into any gear except 5th once hot, I have to shift into 5 then 1 or 2 to get started once its been in neutral??! Also does not grind when I double clutch it so something with the syncros?? might be wrong. Most miles empty but have towed a 3500 300 miles and 6K lbs for maybe 3K miles.
Old 04-16-2003, 01:47 AM
MonroeDiesel's Avatar
I ve got Redline MTL in the 6 spd and I love it. Little rough going into 3rd.
Old 04-16-2003, 02:34 AM
Kimrey's Avatar
62k, and seems ok. Like everyone else a bit notchy. I'm a part tine truck driver and I try to shift my truck smooth as well.
Old 04-16-2003, 07:18 AM
MikeyB's Avatar
Going into third is a little notchy, especially when cold. Going into reverse is a pain but I found a trick. Go into 5th gear first before trying reverse. Slides right in with very little effort.<br> ;D<br><br>MikeyB
Old 04-16-2003, 10:00 AM
Dieselbuilder's Avatar
Well I'm quite surprized, seem like a small percent has serious problems. It sure seems that more quality controll is needed at the factory before shipping product. The only time I have a problem getting into 3ed gear is downshifting around a corner With a 5 would not be to bad but with 6 you have that extra slot to get it into?
Old 04-18-2003, 09:44 AM
Pit Bull's Avatar
Mine shifts great. If it is 30 degrees or colder the first shift into third has to be done slowly. All other gears are smooth, even reverse. Now I don't try and speed shift, it's a truck transmission. I will stay with the OEM lube until I'm out of warranty. Figure by then we will have more information on how the other lubes are working in the NV5600. I figure I will do the first OEM lube change a 40K miles. That will be a couple of years. Also I don't tow or haul anything. Mines a Mall cruiser, just got it for the good looks
Old 04-24-2003, 08:16 PM
tmccormick's Avatar
Well seems like most just have a slight gear engagement issue.
Deiselbuilder, your friends that are having problems with this growl does it do it just in one gear (5th-6th, 50mph) or all and what are the engine rpm's that it accures? Also did they feel any vibration on the floor board/go pedal when this was happening, did the tranny shift OK otherwise?
Reason i'm asking is that I seem to have this &quot;growl&quot; also but mine is at it's worst in 5th (50-55mph) and 6th gear (65-70 mph), 1900-2100rpm and it is getting worse every day &gt; And just so no one thinks it's the exhaust drone I know what that is but what i'm hearing and feeling leads me to believe I may have a tranny issue also.
Old 04-26-2003, 06:27 AM
HC
HC's Avatar
128,000 miles on mine; still a bit of crunch into third, but really drives better now than when new. Many highway miles; I feel like I'm still breaking in the syncho's. Usually driven easy with light load; extensive use of exhaust brake so the tranny gets some workout in both &quot;up&quot; and &quot;down&quot; shifting. Original clutch, too.<br><br>Been changing with the factory lube at not more than 50k per round, but, may check out the Redline at my next change.
hivoltage
10-03-2008 07:43 PM
dieselfitter1
24
12-01-2007 12:01 PM
rustyshakelford
11-09-2007 10:52 PM
Cole_56
28
08-24-2007 11:36 PM
Gotlift01
03-12-2006 05:44 PM
Quick Reply: Hows everyones 6speed
