How To Tell
Old Sep 17, 2008 | 04:03 PM
cowboy2526's Avatar
How To Tell
How do you test to see if the vp44 is failing.
Old Sep 17, 2008 | 05:55 PM
blackdiesel's Avatar
Registered
For starters, check the codes, 0216 is one of the ones you don't won't to see. Check fuel pressure to it. see if your lift pump is bad also.
Old Sep 17, 2008 | 06:01 PM
cowboy2526's Avatar
no codes are coming up on it. so what does that mean. it wont run for nothing, its like its falling on its face.
Old Sep 17, 2008 | 10:23 PM
br2500ctd's Avatar
Could be bad fuel. I have seen at least one perfectly good VP-44 swapped out when the culprit was bad fuel.
Old Sep 17, 2008 | 10:28 PM
Mt Ram's Avatar
Does it smoke black, blue, or white? Check the air and fuel filters first.
Old Sep 17, 2008 | 10:31 PM
cowboy2526's Avatar
No it barely smokes at all even at WOT. I will change fuel and air filters tommorrow. What are some good filters or should i just get some cheap ones to just verify if that is indeed the problem.
Old Sep 18, 2008 | 01:29 PM
Registered
Did you check the pressure to the pump?
Tackdriver
Jan 22, 2003 07:45 AM
bigbaddiesel
Jan 5, 2003 10:09 AM
OH Sick
Dec 10, 2002 04:32 PM
Commatoze
Oct 11, 2002 11:03 AM
