How much does a NV4500 weigh?
Old Oct 21, 2010 | 11:40 AM
Junk Man's Avatar
This would be helpful????
http://www.harborfreight.com/450-lb-...ack-39178.html
Old Oct 21, 2010 | 12:04 PM
patdaly's Avatar
Might work for just the trans, no way with the TC attached,
Old Oct 21, 2010 | 02:39 PM
Tate's Avatar
Weight wise, that jack would be fine. But the base is small, and with a t-case attached, would either want to roll on the top of the jack, or just tip the jack right over. If you just have one tranny to do, that jack would be ok. If you plan on doing a couple, get a real jack.
I got one like this for less than $300, and its been a god-send.
FWIW, a NV4500 is around 200 lbs., and the 241 is around 70-80 lbs.
Old Oct 21, 2010 | 04:52 PM
patdaly's Avatar
Man, i am getting old, that MN4500 felt a lot heavier than that............
Old Oct 21, 2010 | 05:16 PM
gorms's Avatar
My NV4500 was 250 on the shipping slip. T-case (241DLD) was around 80 lbs.
Old Oct 21, 2010 | 09:07 PM
KATOOM's Avatar
(NV4500HD) is 250 lbs and transfer case (NV241HD) is 100 lbs.
Old Oct 22, 2010 | 07:58 AM
patdaly's Avatar
OK,OK, I am getting old........................
Guess it is time for me to purchase a tranny jack.
Old Oct 22, 2010 | 10:15 AM
Junk Man's Avatar
I don't WANT to do any but unfortunately, I'm nursing my 3rd gear syncros along. Hopefully no problems until Spring. I have to do the heater core in the next week or so.
Old Oct 22, 2010 | 11:29 AM
Wyoming Geezer's Avatar
I used my motorcycle jack for the NV4500. Without the t-case it is very managable, as it is somewhere around 150-175#. When I changed over to the NV5600, WOW, around 400#. went to the rental store and got a real transmission jack. Way safer and easier. Worth the $60 fee.
BTW, does anyone think there is any comparison to the NV4500 vs NV5600. Don't waste time or money on trying to save a few bucks on the oil either, been there, tried that.
Old Oct 22, 2010 | 12:50 PM
KATOOM's Avatar
Yea, the NV5600 is heavier at 360 lbs. But what do you mean by comparison? Theres lots of opinions about the two but other than that.....
Old Oct 22, 2010 | 01:34 PM
flynhigh205's Avatar
Thats the exact same one I used when I did my clutch job on my truck. I have a the NV5600. I had to use some wood and take my tires off to make it work. It is a ok jack for the price. Without it I could of never done it. You will have to take the t case off its just easier. Good luck, its loads of fun getting them back together.
Old Oct 22, 2010 | 01:46 PM
Tate's Avatar
Thats where a real tranny jack is handy, as you can tilt it on different axises. I did my first two tranny jobs on a little scissor jack like the first posted. It was a pain, I was lucky it was just a 2wd. All the 4wd ones I have done/helped was with my new jack, and never dropped the t-case on any of them.
Junk Man
Jan 3, 2010 09:19 AM
tool
Oct 11, 2006 04:28 PM
pmtg
0
Mar 16, 2006 10:54 AM
SoTexRattler
Jun 27, 2005 10:25 AM
Hoss
Mar 15, 2004 01:36 PM
