How do I crank the engine without it starting
Old Nov 9, 2007 | 11:48 AM
turbomike's Avatar
I'm getting ready to install a rebuilt turbocharger. I read somewhere that I should crank the engine, and keep it from starting, to build up oil pressure and flow to the turbo bearings. So that the turbo doesn't start spinning too fast without an oil supply. How do I crank a diesel engine and prevent it from starting ?
Old Nov 9, 2007 | 11:50 AM
1-2-3's Avatar
Just a plain ole guy
Pull the plug on the lift pump. it'll run a liitle bit till it runs out of fuel from that point on, but that means you'll have to reprime it again.
Old Nov 9, 2007 | 12:02 PM
Mike D's Avatar
No need.. Once you have the charger installed just pre-oil the charger before attaching the oil supply line.
Old Nov 9, 2007 | 01:29 PM
lotero's Avatar
yup thats all you need to do.
Old Nov 9, 2007 | 01:35 PM
justcampin's Avatar
buy a 2003 model
Old Nov 9, 2007 | 05:22 PM
george7941's Avatar
If you unplug the harness at the VP ( and it is easy to do ) the engine will crank but not start.
Old Nov 9, 2007 | 05:54 PM
wurkenman's Avatar
Maybe its just me, but after I had to put in a new VP, I dont want that thing turning ever again without fuel in it
Old Nov 9, 2007 | 09:49 PM
need12v's Avatar
you can pull fuse 9 or 10, can't remember which off the top of my head and you will get a crank no start. All you need to do with a new turbo is like above suggested.
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Feb 28, 2011 02:36 PM
JaimeG
Mar 26, 2009 06:58 AM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
