How to do a code check on a 99'
Old Mar 15, 2008 | 07:27 PM
Taxidermyman's Avatar
Stupid question with what I think is an easy answer: What is the procedure for doing a code check on my 99 24v? I have looked all over with no luck and a simple answer. Also, does anyone know a page with all of the codes listed? Thanks from a green diesel man.
Old Mar 15, 2008 | 11:24 PM
glenn-k's Avatar
Code checker - $39 ? at Harbor Freight. Also some at various parts houses. Plug it into the socket under the dash near the throttle/steering col.
The code info comes with the checker or do a search here. All listed will be with the checker or may be on a cd that comes with it.
It will erase them also. If you don't get a good read the first time try again. If reset and still a problem the code will appear again.
Old Mar 16, 2008 | 02:12 PM
sheriffav8r's Avatar
Turn the key on, but don't start it, turn if off, turn it on but don't start, turn it off, turn it on but don't start and leave it on. The coded will be displayed in the odometer window. Some will clear by themselves after a certain number of cycles. Do a google on dodge dtc for codes, or list them here and we'll check them against our manuals....
Old Mar 16, 2008 | 06:56 PM
Thanks guys im gonna give it a try...
Old Mar 16, 2008 | 07:43 PM
mslashbar's Avatar
Key trick won't work on a 99, you need to use a reader. Autozone and Checkers will do it for free if you have one nearby.
madhat
68
Oct 25, 2015 08:25 AM
Adam3291
May 2, 2008 10:08 PM
Gary C
Mar 15, 2004 02:53 PM
ck1
May 10, 2003 08:27 PM
