Holley HP 150 Gerotor Fuel Pump
Check this pump out... http://www.holley.com/12-150.asp
I know most people don't suggest the Holley pump as a replacement for the stock lift pump. I noticed this one is a gerotor fuel pump like the raptor and others, but it doesn't say anywhere its ok for diesel.
Has anyone tried this pump out?
Would you suggest it?
I wonder if using a seal kit for alcohol rating would be better for diesel? I know many pumps like the holley and similar have an alcohol conversion kit which uses different material seals, might be worth a try.
I have that exact pump on my truck. Its been running for a few years now and no issues (knock on wood)..I didnt use the regulator that came with it, I just run without. 17psi is what my gauge always says. For a gear pump it is quiet-but if i listen with the window down ya can hear it some. I recomend it
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
heavyJ
Oct 25, 2007 09:08 AM
