High Idle???
High Idle???
We had to put another injection pump on and now we got a really high idle i think. It Idles no load at 900-910 RPM. Is this normal, or is the Camshaft/crankshaft position sensors bad? Just wondering. Also too we have a rough idle, Industrial Injection said that the keyway could be off a little in the gear and that is what could cause this.
Thanks
Cody
Thanks
Cody
well we cant beat it too bad we got to get a bigger turbo first. But i mean we have had it too 30psi and no troubles. Also the rough idle is getting more pronounced. It is going in through the RPM range when you are cruising with no load on the motor. The dealer round here thinks it is a camshaft position sensor, beings it has 142000 miles on it. or they were saying it could be the crank postion sensor also. i need help on this one guys. we are taking to the nearest dodge dealer and having them hook up their scanner for $37, which aint to bad. I hope it is not our "Special Pump" from Industrial Injection. What do you all think is the problem?
Thanks
Cody
Thanks
Cody
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
