Help Tranny guys!!
Old Oct 15, 2007 | 12:07 PM
YR660R's Avatar
Help Tranny guys!!
My truck is shifting funny, it shifts fron 1-2 at the correct time, but then shifts into 3rd way too early, it needs to stay in 2nd a lot longer before it shifts, Wondering what I need to change in the valve body to correct this. I have messed with the tv cable, and apps reset, checked apps voltage, nothing, I need to change something in the vb, I have had them apart, so I know what i will be doing, just dont know what I need to modify. Please let me knoe and thanks
I have also changed throttle valve springs with no result.
Eric
Old Oct 15, 2007 | 12:16 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Please fill out your sig. Details of your truck are needed so we all can help you out.
Old Oct 15, 2007 | 12:21 PM
YR660R's Avatar
Woops, my bad, until then, its a 99, 4x4, auto, 47re, goerend converter, suncoast overhaul. edge comp.
Old Oct 15, 2007 | 12:25 PM
JPR Ram's Avatar
hmmmm, I'd say the TV cable is outa adjustment.
Old Oct 15, 2007 | 12:37 PM
YR660R's Avatar
Its not the throttle valve cable, I have played with that non stop and can not get results, its to the point where if I tighten it anymore, the throttle will only open to about 90% cause the tv cable tightens up.
Old Oct 15, 2007 | 05:15 PM
j-fox's Avatar
I sent a PM. hope it helps!
Old Oct 16, 2007 | 09:50 AM
YR660R's Avatar
Ok, I know where the 2-3 shift valve and spring is, what would I need to change with that valve?
There has to be a way to alter shift timing from inside the valve body.
Old Oct 16, 2007 | 05:13 PM
j-fox's Avatar
A stiffer spring delays the shift to higher speed.
Black Dog
Dec 3, 2009 08:18 PM
the496rocket
Sep 18, 2008 12:14 PM
CTDowerTN
18
Sep 13, 2007 12:23 PM
04ctd
Sep 10, 2006 02:58 AM
bentwings
Jul 9, 2004 02:23 PM
