Help me Stupid question time!!
Old Aug 18, 2006 | 11:58 PM
runamuk's Avatar
My buddy installed a new lp , fuel filter and Vp 44 today and we are getting white smoke, No codes, just white smoke no power and it's very noisy when put into drive. 2000 4x4 w/190k
It was only driven around the block a few times to build teperature.
Any advice would be appreciated.
Rick
Old Aug 19, 2006 | 04:45 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Did you use the woodruf key that came with the pump, or reuse the old one?
The key is designed and numbered for the pump, as this is how the initial timimg is set.
Old Aug 19, 2006 | 10:36 AM
runamuk's Avatar
Yes new pump came with new key attached. Put in place with slot in gear at 12o'clock.
We then hot wired the Lp and bled all the lines
Rick
Old Aug 19, 2006 | 11:41 AM
rich's Avatar
it does sound like a timing issue
Old Aug 19, 2006 | 12:39 PM
runamuk's Avatar
Just looked this morning key is not correctly in key way probably have to replace it.
I 'll keep you posted
Rick
Old Aug 19, 2006 | 02:33 PM
mgstroker95's Avatar
That suxs. Good luck bro
Old Aug 19, 2006 | 06:49 PM
runamuk's Avatar
HA! HA! We saved the key and reinstalled works perfectly now!!!
Thanks for the help guys!!
Rick
Jim Lane
Mar 23, 2013 09:31 PM
bigredbrick
Jul 13, 2008 04:12 PM
usmc2311
Nov 17, 2007 09:27 PM
Hoss
May 19, 2005 02:28 PM
JKM
Mar 22, 2005 06:29 AM
