Help! Fuel Pressure
Old Feb 8, 2009 | 03:02 PM
progrower's Avatar
Help! Fuel Pressure
I just installed isspro fuel, boost, and egt. My fuel pressure only reads around 3-4 psi. at idle, sometimes less. Changed the fuel filter thought maybe it was dirty. Now I cant get it to prime back up. I took the little screw out of the isolator and cant get nothing through it. Is there a trick to get these things to prime up or is the lift pump bad? Thanks
Old Feb 8, 2009 | 04:03 PM
louddodge's Avatar
The same thing happened to me on an 01 and the lift pump had died.
Old Feb 8, 2009 | 05:22 PM
98whitelightnin's Avatar
Ya bud your lp is dead. You need to get 1 asap and hope it hasnt killed your ip. Dont waste your time and money on a stock replacement, get a Fass or Airdog.
Old Feb 8, 2009 | 10:08 PM
progrower's Avatar
I think I am going to get an Air Dog 100. Just bought the truck and put the fuel press gauge on. Don't know how long the LP has been weak or not working at all. Hope it wasn't to hard on the VP. Will the motor run normal even if the LP is not pumping at all?
Old Feb 8, 2009 | 10:24 PM
Dr. Evil's Avatar
Yes it can.
Get the Airdog 150 and be done with it.
Old Feb 9, 2009 | 09:58 AM
pull-do's Avatar
I got the Airdog 100 a couple of months ago,,,,,,, love it, easy install, and very helpful on the phone, good tech service also when I thought I had a problem, ,,,,, but it was my error , holds steady fuel pressue according to my ISSPRO gauge at about 14.8 to 15 psi.
Old Feb 9, 2009 | 10:10 AM
jentas's Avatar
Good choice on the Airdog 100--you really can't go wrong with that unit (unless you plan on going over 500 rwhp at some point, then you should get the 150).
Most of the stock lift pumps had a bypass valve that allows the vp to suck through the dead lift pump. This creates a high heat, low lubrication type scenario for the vp, which supposedly relies on the constant, unrestricted flow of fuel to cool and lubricate. The motor will run pretty normal with the dead lift pump, but there is a high probability that the vp has been damaged if you've been running like that for a long period of time. Hopefully, it's still ok. Good luck.
Old Feb 9, 2009 | 11:22 AM
progrower's Avatar
I just ordered the airdog 100. Do I have to drop the tank or take the bed off to hook up the fuel lines at the tank?
Old Feb 9, 2009 | 12:01 PM
pull-do's Avatar
On my 01, no, it's snug with the head and arm stuck up there but's very do-able, mines a long bed, I don't know if that matters or not----- I took my water hose and spray nozzle and sprayed the top of the tank good to get all the grime out of the way, then blew it off with my air hose.
The harder piece to me was the return line hook up,,,, but I laid out the cut lines on the filler tube and cut it with a reciprcating saw between the lines so I could twist off the hose fairly easy, then made the final cuts outside the truck.
Old Feb 9, 2009 | 12:03 PM
jentas's Avatar
With the 100, you can use the stock fuel pickup. You don't have to drop the tank or do anything with the bed unless you install a draw straw.
The most difficult part was fooling with the connection on top of the tank, just because it's hard to reach and hard to see what's going on there. The rest of it was very straight forward. Make sure you put the pushlock fittings in the freezer before assembly.
dodgeguy71
17
Jan 19, 2012 12:52 AM
MoparRiggan
Jan 5, 2006 11:09 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
