help a bonehead
Old Feb 7, 2007 | 01:27 AM
frenzel's Avatar
help a bonehead
Well I went to drain the water seperator and I pulled an oops. I think I drained too much because the truck started and died after about 10 seconds. I then ran the battery down trying to cycle the pump over and over again. It probably doesnt help that it is in my driveway facing uphill at a pretty steep angle. I filled the filter back up with fuel but it still wont start. what to do now? Crack open the lines? If so where do I do this? Where they go into the valve cover?
Old Feb 7, 2007 | 01:36 AM
roberts11260's Avatar
Get some juice to those batts and get her started.
Listen for the lift pump, it has to be kicking on while cranking at least.
hope this helps
my 2 cents
Old Feb 7, 2007 | 04:39 AM
deezel's Avatar
crack loose fuel lines you can get to and once you start to get fuel tighten.if you don't get fuel lift pump could be bad .
Old Feb 7, 2007 | 10:34 AM
frenzel's Avatar
Is the lift pump supposed to be loud because mine is barely audible. Just sort of quietly clicks.
Old Feb 7, 2007 | 10:42 AM
Hillcountry's Avatar
The fact that your filter bowl is not filling suggests that the lift pump is not working. You should hear it whirring...even so sometimes it runs but produces no pressure. Get a test gauge with a schrader connection and test the pressure.
Old Feb 7, 2007 | 10:58 AM
smokindog's Avatar
1) You need to verify that your lift pump is working. The easiest way to do this right now is to get juice back in your batteries, disconnect the inlet from the filter housing and bump the key. If you squirt a liberal amount of fuel you're in business. If it just trickles out you need a new lift pump. Anything in between liberal and trickle will be enough to start the truck, but could spell death to the injection pump soon. You're goal right now is to get it running.
2) If you have fuel reconnect the inlet to the filter housing. Get you truck to level ground. Get yourself a 19mm open end wrench and crack injectors #1 and #3. Bump the starter to activate the lift pump a couple times, then crank for no more that 30 seconds at a time. It will start like this, but idle very rough. Tighten the injectors and be on your way.
Last thing.... why were you draining water/fuel out of the canister in the first place? If your WIF light didn't come on there was no reason to touch it.
Old Feb 7, 2007 | 01:28 PM
frenzel's Avatar
Told you I'm a bonehead. It gave me a few stumbles and I thought water. It was the first time I had ever touched it. Going out now. update soon
steve0000
Feb 1, 2009 09:56 AM
rebelrider
May 1, 2007 01:38 AM
Mopardan
18
Aug 25, 2006 04:06 PM
FrdRdnk
Feb 12, 2006 10:54 PM
