He351vgt
Old Aug 9, 2008 | 12:37 AM
JoeCanuck's Avatar
He351vgt
Good day. Has anybody played around with the HE351VGT turbo? I've seen these 6.7l turbos cheap on ebay. I like the idea of variable vanes for less turbo lag. Would they fit on a 24v?
Thanks.
Old Aug 9, 2008 | 07:21 AM
GFB's Avatar
GFB
They're electronically controlled and therefore won't work on an older truck.
Old Aug 9, 2008 | 07:44 AM
JoeCanuck's Avatar
The vanes are electronically controlled? Is the wastegate also electronically controlled or still pneumatic?
I'd like to see the guts of one of these...or at least the schematics. After all, as we all know, electronics can be made to do our bidding...
Old Aug 9, 2008 | 08:27 AM
Number47's Avatar
the vanes act as the wastegate
Old Aug 9, 2008 | 10:51 PM
Jdonoghue's Avatar
Someone would need to come up with a controller box to run the VGT. It would be pretty easy to capture the needed information off the CAN bus. Something I'd consider doing except that I have way too many projects already, and I have to work, too!
Old Aug 9, 2008 | 11:40 PM
JoeCanuck's Avatar
I'm a ways away from doing a turbo so I'm researching for now. I've been a fan of the variable vane concept since chrysler did it with their 2.5's way back when. Minimum lag and lots of air when you need it...also water and oil cooled bearings.
Old Aug 10, 2008 | 11:15 AM
HOHN's Avatar
Technically, this is NOT a variable vane charger like the garretts on the old Chrysler/shelby chargers were.
A "variable vane" changes the radial angle of attack the gas flow has against the turbo blades.
The Holset VGT varies the flow orifice by sliding in the axial direction.
So while they try to achieve the same thing, the hoslet approach uses fewer parts and operates axially vs the radial adjustment of the VNT design.
I think a VGT charger would work well on an older truck like mine. MOst of the reliability problems I have heard of are overwhelmingly related to the ECM calibration of the newer cleaner engines that soot up the charger so heavily.
JMO
Old Sep 12, 2009 | 02:20 PM
Tow-mater01's Avatar
i have a fully functional vgt on my 1997 12 valve.... by that i mean FULLY functional... exhaust brake, spools instantly, my truck can get 12psi boost just by revving in neutral and the housing can open so large it wont spool
and best of all... NO ELECTRONICS
for pics and info pm me...
Old Sep 14, 2009 | 02:56 PM
PaulDaisy's Avatar
If you are willing to share, and we hope you are, please post the info here for all to read. Don't limit is to PMs, those help nobody.
Old Oct 4, 2009 | 07:38 PM
12VEG's Avatar
PM sent a few days ago, looking for all of the info I can get on this conversion. I'm thinkin about doing one and I'm doing my homework...
Old Oct 6, 2009 | 03:00 PM
12VEG's Avatar
hellooooooo?
ttcfan4476
73
Apr 18, 2011 09:55 PM
Tow-mater01
Feb 12, 2011 10:05 AM
1985cucv
Sep 6, 2009 02:21 PM
ttcfan4476
Aug 25, 2009 06:46 PM
ttcfan4476
May 4, 2009 03:07 PM
