Greasable U-joints?
Old Mar 3, 2006 | 12:42 PM
hotdram's Avatar
Greasable U-joints?
Tried the search and no luck, so:
Does anyone make a replacement u-joint for our trucks that has a grease fitting?
~Rob
Old Mar 3, 2006 | 12:57 PM
Red3quarter's Avatar
Are you talking about on the axle shafts or the driveshafts? I know i've seen greasable uoints for the driveshats before but i never had any put on a truck. On my old 95 ram i had installed greasable ujoints in both axle shafts. I wanna say they were spicer ujoints but i'm not too sure on that.
matt
Old Mar 3, 2006 | 12:59 PM
hotdram's Avatar
Thanks B3Q,
I am talking about the drive-shafts
Will look into them.
~Rob
Old Mar 3, 2006 | 01:04 PM
abc4yew's Avatar
Guys, I know I'm a 3rd gen guy but...yep you can get Spicer Originals ujoints for your shaft. Any good driveline shop will have them. I priced them at truck parts places and my driveline guy was cheaper because he got them straight from the Dana Spicer warehouse. Should run about $30 to $35 a piece. I don't have the part #'s for you but they are available at a Dana Spicer driveline shop. Hope this helps. Spicer makes several lines of Ujoints....The originals are the driveline guys favorites for lasting. ks
Old Mar 3, 2006 | 02:19 PM
Mike D's Avatar
Napa sells the greasable u-joints.
Old Mar 3, 2006 | 03:10 PM
mini14's Avatar
http://www.quad4x4.com/Dodge%20Frt%20Axle&Steering.htm
the reason for a non greasable is that they are much stronger....only get the greasable if u will religiously grease them..i personally like the greasables, have never had a greasable go bad, i have had to replace the stock nogreaseables on my truck. front axles i went with the non, driveshaft i used the greasables.
Old Mar 3, 2006 | 04:40 PM
CTD NUT's Avatar
What Mike said....
I have never had a problem getting greasable u joints for just about anything at NAPA (including our Dodges).
If OEM Spicer parts are your thing, you can go to your local Dana/Spicer dealer and specify greasable u joints.....I have never heard of a non greasable Spicer u joint application that couldn't be spec'd with a greasable version.
Old Mar 3, 2006 | 06:33 PM
PourinDiesel's Avatar
Rob,
Check out www.rockauto.com they have AC Delco and Precision brand greasable and non greasable joints.
They are cheaper than buying form a store.
Old Mar 3, 2006 | 07:05 PM
hotdram's Avatar
Thanks y'all
~Rob
Old Mar 5, 2006 | 09:46 AM
RowJ's Avatar
Rob
PM'ed you about where I got mine.
RJ
Old Mar 6, 2006 | 12:28 PM
Commatoze's Avatar
~Rob
Have you tried Lakewood Performance? Summit Racing carries that line.
Old Mar 6, 2006 | 07:34 PM
willysrule's Avatar
buy good ones, a bad u-joint can take ALOT of stuff with it when it explodes...I've junked many axle shafts, yokes and ripped a hole in the floor of my Jeep due to u-joint falure...don't cheap out, get the best ones you can find...
I Stand Alone
Jan 8, 2011 05:30 PM
rbertalotto
Feb 17, 2010 06:06 PM
itr.#1446
Mar 21, 2008 08:38 PM
Rdway60
Aug 30, 2006 10:29 PM
Mexstan
Feb 9, 2006 01:54 AM
