Fuel Temp Sensor readings
Old Jan 9, 2006 | 08:02 PM
Gopfan's Avatar
I have been having some issues with my 99 Dodge 2500 Cummins 24v. I recently replaced the injector pump, lifter pump and fuel filter due to injector pump failure. Installation went well and truck was running great then it suddenly died on way to work. Suspected injector pump again, so had it bench tested by local shop, all ok with IP. Have 9psi from lifter pump, have crankshaft sensor signal and camshaft signal. I did find my fuel temp sensor reading is way out of wack ... like 152,500°F or something crazy like that. Do any of you know if that will keep engine from running? I am assuming sensor is bad but cant find any info on how to test it. Any help would be greatly appreciated.
Jason
Old Jan 9, 2006 | 08:39 PM
Shovelhead's Avatar
Administrator / Scooter Bum
If that lift pump fuel pressure is at idle, that might be part of your problem.
With a good stock Lift Pump, Fuel pressure at idle should be around 15 psi and only dropping to around 10 psi at Wide Open Throttle.
There have been a few cases of Crank & Camshaft sensors going bad.
It might not hurt to swap them out for new replacements.
Old Jan 9, 2006 | 08:46 PM
Gopfan's Avatar
Ok thks, may try that. Alittle suspicious of that temp sensor reading though. Was able to find that Bosch max recommended fuel temp is 160°F but no indication if a reading higher than that will tell ECM to shut down fuel supply.
Old Jan 9, 2006 | 08:52 PM
Shovelhead's Avatar
Also check all the boost hose connections to be sure one hasn't partially slipped off, or a clamp is loose.
Considering that aluminum melts at around 1300 degrees, I would think a fuel temp reading of 152,000 degrees would make the ECM think you were driving on the sun.
Old Jan 9, 2006 | 09:05 PM
Gopfan's Avatar
Yep, would think so ...thks for your input, will check what you have suggested then will probably look into getting new temp sensor to start.
Old Jan 9, 2006 | 10:36 PM
newriverSpecon's Avatar
I haven't heard of a fuel temp sensor before. I know there is a heater in the filter and probably has a sensor associated with, but I'm unsure.
Randy
snowmanx
Mar 31, 2009 08:42 PM
tyssniffen
Aug 22, 2008 03:46 PM
SilverRam3500
26
Jun 1, 2008 07:20 AM
5.9Excursion
Dec 24, 2007 09:54 AM
chasd60
May 3, 2005 10:11 PM
