fuel tank filler neck
Old Dec 27, 2009 | 02:58 PM
stock659's Avatar
Is there a screen in the neck at the top of the tank. I tried to syphion out the fuel only getting a gallon or two. I need to remove the fuel to lower the tank to install a draw straw. If anyone has ideas let me know. Thanks stock659
Old Dec 27, 2009 | 04:09 PM
Shovelhead's Avatar
Administrator / Scooter Bum
There should be a "roll-over/anti-siphon" valve in the neck.
You might be better off disconnecting the filler tube from underneath the truck. (If your fuel level is low enough)
Old Dec 27, 2009 | 07:18 PM
mr bill's Avatar
Just raise the bed on the tank side. I just did this recently to change out the fuel sending unit and found it easy to do with a bottle jack between the frame and the bed.
broncobilly
May 9, 2012 09:30 AM
Machinos
Jul 6, 2010 01:18 PM
p.o.s.
Apr 16, 2009 01:23 PM
wheelo90
Mar 22, 2006 07:22 PM
I PASS GAS
Nov 8, 2004 09:04 AM
