fuel tank filler neck
All,
I need to replace the leaking rubber fuel hose, on my fuel tank filler neck. The hose which connects the fuel filler tube to the tank. I fogot to remove the hose when I was up at my parents place yesterday (where I have my 93 W250 parked). Anyone know what size fuel hose I need, for the fuel tank filler neck?
I had the same problem when I first got my truck. Mine turned out to be the filler tube and not the hose. Dirt accumulated under the hose which caused the tube to rot through. I fixed mine by soldering the tube holes shut.
I purchased mine at advance auto, they have to order it from there aftermarket supplier. Hopes this helps. Tomorrow I'll look at home and let you know what the size is.
Make sure you replace it using USCG fuel rated hose and not a section of radiator hose, contact with the diesel fuel will destroy it in short order.
You can get it from Hose Man, most hydraulic hose shops also boat shops.
I'll have to see if I have the part number, was a special order part. I'll also check at advance and see who they order it from maybe get a manufacture and number. It'll be tomorrow as I'm at work today and get off tomorrow morning work 24 hr shifts.
