Fuel Pressure Sender and Fass
Where are you guys mounting your fuel pressure sender with the 95 series Fass, I am just curious, and what kind of pressures are you seeing. Thanks
My fuel pressure gauge is a 'T' about 16" back from the Inj Pump...right into the fuel line. 16" reduces vibration form pump but still gives reading after filter. Use a needle valve because VERY little pressure is needed to give good reading. Full pressure will start your gauge making noise and bouncing the needle around.
FASS fuel pressure is determined by the spring in the pump...not the gph rating. I believe the spring they use now on the 95 gph pumps is indeling around 16 psi.
Sorry, you said 95 series FASS. Their web site lists a 95/95/1008. The 1008 spring idles at around 20 psi on mine...but that's a 150 series so...??
RJ
RJ
This has been a popular option:
http://www.jegs.com/webapp/wcs/store...0002_746566_-1
ALSO Power By Poole and Vulcan Performance have similar fittings.
AlCorr
02-07-2008 06:52 AM
rjm022
07-08-2006 06:30 PM
