Fuel Pressure Gauge
Old Oct 8, 2004 | 11:16 AM
twhite's Avatar
Fuel Pressure Gauge
I need the complete fuel pressure gauge and all associated parts for installation. I have a pillar post already installed which would accept the gauge. The gauge needs to be 2 and 1/8 inches. Does anyone know where I could find this gauge?
Thanks
Tim White
Old Oct 8, 2004 | 11:31 AM
Dr. Evil's Avatar
Tim,
Look at the Isspro EV series:
http://www.isspro.com/proddetail.php?prod=R5604
Unlike many of the other guages out there (autometer etc.) it is the correct range to measure fuel pressure. Also, mechanical guages are much more dependable, IMO.
Old Oct 8, 2004 | 11:42 AM
firestorm's Avatar
I have westech gauges, fuel psi range is 0-30, from Genos.
Dodge acc. http://216.167.41.9/CoastalData/Cate...DID=30&CATID=1
gauge http://216.167.41.9/CoastalData/show...ID=891&CATID=1
hose http://216.167.41.9/CoastalData/show...D=1195&CATID=1
Old Oct 8, 2004 | 11:59 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Rod at Wildcat Diesel Performance has the complete Isspro EV Fuel pressure gauge setup.
Quality parts make a quality job that you only have to do one time.
Old Oct 8, 2004 | 07:33 PM
gamiller31's Avatar
If I had it to over, I would have gone w/the westach double gauges. 2 gauges per hole in the pod. I have not had any problems w/my gauges, but would be nice to see fp pre and post filter, and egt pre and post turbo, as well as boost, and an oil pressure gauge that works better than the stocker.
Old Oct 8, 2004 | 09:36 PM
firestorm's Avatar
That is why I went Westech. Fuel PSI., Boost/EGT, Trans temp./engine temp. Then I added an oil psi in another pillar mount, mouted to my tri-pillar.
Old Oct 9, 2004 | 07:36 PM
Dr. Evil's Avatar
twhite,
Some people (including me) feel the mechanical guages are more durable and offer better accuracy as they withstand the pulses from the VP-44 better.
Old Oct 11, 2004 | 07:02 PM
Tazman's Avatar
Dr. Evil is absolutely "frikkin' right".
Mechanical with an isolator to keep the stinky stuff outa the cab.
Old Oct 12, 2004 | 12:12 AM
Dr. Evil's Avatar
Thank you, Mr. TAZ
But, my preference is for Mechanical with NO isolator. With quality parts and a competant installer you'll never have a leak.
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
