fuel pressure ?
Old May 8, 2008 | 06:53 PM
dieselho's Avatar
fuel pressure ?
Will there be any pressure at the gauge with a bad LP? I will have 14-14.5 psi at idle, and 10 psi at .75 throttle. everything running great. Then come to a stop and suddenley pressure hovers around 10 psi, and remains the same under acceleration. Then it will decide to return to normal when it desires. usually after 3 miles or so. (city driving). LP or Gauge or ?
Thanks Dieselho
Old May 8, 2008 | 09:25 PM
mslashbar's Avatar
Do you have a issolator? If so I'd be suspicious of the issolator, if not it's probably the pump. That's what the stock pumps do when the're getting ready to fail.
Old May 8, 2008 | 11:02 PM
dieselho's Avatar
I had an isolator when i first purchased the FP gauge, and could not get an accurate reading so i by-passed it. I'm still curious though if there will be any pressure reading at the gauge if the LP is bad. I tapped into the fuel line just before the schraeder valve on the VP-44.
Old May 9, 2008 | 08:52 AM
mslashbar's Avatar
No there would be no pressure before the vp44 if the lift pump was completly out, but they usualy die slowly.
Old May 9, 2008 | 06:45 PM
dieselho's Avatar
As I figured. Thanks for the input.
Old May 9, 2008 | 09:10 PM
WestTN's Avatar
The LP impeller is plastic. If yours is failling like mine did, the hole in the impeller is getting worn out and no longer fits the drive motor shaft properly. This allows slippage and causes the pressure to vary. If this is your problem, it will fail very quickly.
Old May 11, 2008 | 10:45 PM
PaulDaisy's Avatar
It is? For what I could tell from close inspection, the LP is a vane type pump with steel rotor and blades, sort of like the power steering pump but small. Failure mode on mine, I am sure, was the bypass valve stuck open. Mine had zero pressure.
Old May 11, 2008 | 11:19 PM
johnh's Avatar
wrong, it's metal
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
