Fuel module check valve?
I have been having trouble starting my truck, the VP is bleeding down, I put a check valve in the line and problem solved. So what stops the fuel from bleeding back to the tank? is there a valve in the fuel module that has gone bad? The overflow valve in the VP is good, but I noticed it has a bleeder, so air can bleed back threw it anyway. I have an OEM carter pump relocated to the tank, is that supposed to stop the flow?
HELP I AM SO CONFUSED!
Bob
Bob
I looked and looked and can not find any air leaks at all. The check valve did the trick for now and I guess I will keep looking. I did hear something about it being a sign of a vp 44 going bad, but could not find it in old posts. I am hoping it will start leaking if there is a leak somewhere. It just started about two weeks ago out of the blue?
Thanks Bob
Thanks Bob
PChouinard
20
12-14-2006 07:48 PM
Ironstone
06-21-2006 04:05 PM
