Fuel gauge problem
Old Mar 10, 2010 | 08:48 PM
kurtswater's Avatar
Fuel gauge problem
I was driving one day and my gauge went from full to empty and the fuel light came on. It is a 2000 dodge 3500 4x4. I was told it most likely was the sending unit. I replaced it with a new one from dodge but gauge still doesn't move off empty. I was then told it was the gauge itself before I bought a cluster it took one out of another dodge and his working cluster didn't let the fuel gauge work either. Mine worked in his truck so I know it isn't the gauge. I can use an ohm meter on the 2 wires at the harness plug on the backside of the front driverside wheel well and it tells me how full the tank is so I know it isn't in the frame rail harness. If I go to the passenger side neg battery cable and unplug the gound wire going to the harness along the fire wall it will work for a sec when I plug it back in then go back to empty. Anyone have any thoughts.
Old Mar 12, 2010 | 12:02 PM
SIXSLUG's Avatar
Sounds like maybe a ground is off or corroded.
nrussell
Jul 23, 2008 08:58 PM
engcogod
17
Feb 3, 2005 08:49 PM
callum
Nov 21, 2004 07:04 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
