fuel filter problems
Old Feb 7, 2008 | 04:26 PM
Vanb's Avatar
I have a 1999 and the rubber grommet where the black and red wires are coming out of is leaking. I called dodge to buy the top of the filter housing and they don't sell it any more they will sell you a retro kit that changes it from my style to the 03 and newer for 1,100 dollars. does anyone know where I can get this part or how I can fix it? thanks for the help
Old Feb 7, 2008 | 05:18 PM
jivemother's Avatar
ebay ,there is a guy that sells alot of take off parts ,check this item #280197995422 just surch around there a few on there
Old Feb 7, 2008 | 06:56 PM
PChouinard's Avatar
I just had this problem and there IS a really cheap fix. First off, that is a plastic plug with a single o-ring. You can get o-rings from any NAPA or equivelant parts store. I think it's a #8 or #10, not sure.
1. Remove fuel filter canister and filter.
2. Remove banjo bolts.
3. Disconnect wire harness from heater element. Then remove wires from heater-side of connector.
4. Remove two bolts attaching housing to engine and remove housing.
5. Remove the TORX screws attaching element to housing.(screws are on the underside of housing.
6. Push (black) plastic plug out through the bottom of the housing.
7. At this point you will see a flat, cracked o-ring. Carefully remove it and go get one that fits.
If you have any problems, PM me and I'll help you through the process..
DJ Turbo.
Oct 13, 2011 09:11 PM
mudturtle
17
Oct 7, 2008 10:27 AM
joe189man
30
May 27, 2008 09:32 AM
Big Smoky
Dec 28, 2007 09:37 PM
AJMartin0321
Sep 26, 2007 09:21 AM
