Front end BANG
Old Jun 4, 2011 | 06:42 PM
pickupman96's Avatar
Front end BANG
I have had this bang in the front end this week. I have checked all the bar ends, ball joints, ext. It sounded like it was coming from the steering box so i changed that and nothing. Its not in the same spot when i turn every time and does not do it when the tires are off the ground. Its loud and sounds like your hitting boiler plate with a sledge hammer but not as loud. Where should i look now??? Thanks in advance
Old Jun 4, 2011 | 08:14 PM
BigIron70's Avatar
Cummins Guru
I would have someone turn the steering for you while you give a look. If it's as loud as you say should be easy to find what's loose or broken. Trac bar loose possibly or front u-joint if 4X4.
Old Jun 4, 2011 | 09:11 PM
i think i may have narrowed it down to the steering shaft u-loints. Could this be
Old Jun 4, 2011 | 09:39 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
If it's happening on bumps, check the snubbers above the axle
Old Jun 4, 2011 | 10:42 PM
I can't really hear it when driving but you can really hear it turning back and forth in the driveway
Old Jun 5, 2011 | 06:43 PM
DIESELWRKS's Avatar
dont know if you have a steering shaft stabilizer.. my DSS when the bolts where loose on one side this made the DSS plate slap the frame when I did small turns.
Old Jun 6, 2011 | 10:29 AM
Midnite's Avatar
I think the steering gear is mounted to a bracket which is bolted to the frame. The bracket may be cracked, and when you turn the wheel back and forth you're putting a lot of torque on it. Note that this would be more of a clunk--not a huge banging noise.
My old 1st gen had this happen, and they actually had to magnuflux the bracket to find the crack. Got a new bracket, and the clunking disappeared.
Old Jun 6, 2011 | 10:47 AM
Polaraco's Avatar
Is it a bang or a clunk? You hear it sitting still? Moving?
Old Jun 7, 2011 | 08:55 AM
RowJ's Avatar
Originally Posted by pickupman96
.....Its loud and sounds like your hitting boiler plate with a sledge hammer but not as loud. Where should i look now??? Thanks in advance
I had the same scenario at 175,000 miles. It is not an uncommon occurance (I learned to the detriment of my wallet) on higher HP trucks around that mileage ....... especially if raced at all.
On mine it was the splines on the front cover of the transfer case.... wearing and then starting to skip. Sounded just like you described....and usually happened in a turn.
But mine was while driving and I could hear it, so maybe not the same thing?.
Old Jun 29, 2011 | 11:27 PM
ellerman's Avatar
I had a random bang in my front end and it ended up being the track bar on the axle end. The bolt had loosened and egged out the hole a little so it would slip and create a bang while doing slow speed turns like into a driveway.
Old Jul 1, 2011 | 05:32 PM
mstep3's Avatar
as was already mentioned, i would check the track bar bolt at the axle if it's doing it when you turn the wheel....i had similar problem with mine & this was the problem....
CapnRam
Nov 18, 2010 07:02 AM
Mountaineer
Dec 22, 2009 04:24 PM
JuzPlaneKrazy
Apr 26, 2007 07:26 AM
dansdad
Jun 22, 2003 05:34 PM
