Front differential cover leaking
Old Sep 13, 2012 | 12:06 PM
Silver R/T's Avatar
I'd like to install new seal/gear oil. What is a good sealant to use and what's proper gear oil I should be using? (how much of it?)
Old Sep 13, 2012 | 06:49 PM
SIXSLUG's Avatar
I used black rtv sealant by Permatex. I cleaned the edge with brake cleaner and applied a good 1/4" bead all the way around and around each bolt hole and let it skin over a little. A couple of blue stick pens cut in half and stuck in two bolt holes will help guide it straight on.
IIRC I used 85/90 Royal Purple for the front.
Old Sep 14, 2012 | 12:36 AM
Silver R/T's Avatar
Do I have to add friction modifier to rear one?
Old Sep 14, 2012 | 08:09 AM
jrs_dodge_diesel's Avatar
Only if you have a limited slip differential.
Old Sep 14, 2012 | 05:50 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Annnnnnnnd to find that out look in your glovebox
Old Sep 15, 2012 | 12:48 PM
Silver R/T's Avatar
Synthetic gear oil states that it already has additive in it for limited slip differential. So I shouldn't have to worry about adding it separately?
Old Sep 15, 2012 | 06:51 PM
gorms's Avatar
I have run royal purple and lucas without any extra friction modifier, origianl LSD now has 230k on it and works good enough.
lilsuzuki4x4
Sep 1, 2011 01:50 AM
Exekiel69
Aug 4, 2008 11:43 PM
stealman1
Apr 27, 2007 02:40 PM
nineback
18
Mar 7, 2007 11:33 PM
gsdog1
Jan 30, 2004 07:58 PM
