Filter between fuel tank and lift pump?
Old Jul 16, 2007 | 10:56 PM
coachgrowl's Avatar
Does anyone have a filter between the fuel tank and lift pump? Should there be one? It seems that could be a reason for lift pump failure. Am I onto something here or is this pre lift pump filter not necessary?
Old Jul 17, 2007 | 06:09 AM
91rangerturbo's Avatar
I put a custom fuel filter /water/fuel seperator setup after the holley blue on my truck. Works just fine.
Old Jul 18, 2007 | 12:27 AM
megamac's Avatar
I have a filter on my line between the tank and the HPFP (FASS). The problem with a stock LP I think will be that you are adding more restriction to an already crappy design. I would look at relocating the LP near the tank and perhaps adding a separator.
Old Jul 18, 2007 | 01:29 AM
pind's Avatar
I run the fleetguard FF5079 pre-filter on my walbro setup. Wouldn't be without a pre-filter / strainer on any lift pump setup. They are reasonably cheap, can be cleaned out with low pressure compressed air if in a bind. (blow through it) and they save a lot of crap from getting to the lift pump.
I know a lot of guys who say " not me, my tank is clean, I never put anything dirty in there, etc" ok fine, so pull your tank out, and see what kind of crap is in there. Since I get to see the effects of poor filtration all the time, I prefer to over-filter, rather than not have enough.
Just thought munchies
Old Jul 18, 2007 | 10:33 AM
coachgrowl's Avatar
Thanks I will install the fleetguard today.
yamarx1
Feb 13, 2009 10:37 AM
HuskerPower
Mar 5, 2008 03:59 PM
SSweeney
Sep 3, 2007 01:09 PM
Leadfoot
20
Dec 8, 2005 09:55 PM
36
Jun 4, 2003 02:30 AM
